Full CD30 set up taken from an 06 Vectra (Facelift).
Includes CD30 CD player and Triple info display (TID).
Also included is user manual and security code. Both items are 'married' together and are ready to plug in.
This item is in exceptional order as you can see from the pictures there is not a blemish. The only issue may be that it has no vents. The CD70 I replaced it with had broken vents so I naturally used these to replace them, so you can simply do the same with your own.
£50
