Thread: Turbo rebuild kits - 1.9CDTi
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Turbo rebuild kits - 1.9CDTi
    Afternoon all.
    The turbo in the Vectra is really starting to whine now and it's not really going away as much when it's hot like it used to. Blows enough oil on a cold start to make the engine judder a bit too. After a bit of research I've found a company that offers a rebuild kit for the turbo for £50. Has anyone used them before? Is this something that a normal garage can fit too? Trying to keep costs down and can't afford an exchange turbo and fitting. Not got the tools or knowledge to do it myself either.
    http://www.turborebuild.co.uk/?p=product&key=1011056720
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Done a bit of digging and it is a genuine Garrett rebuild kit, not cheap aftermarket parts. Can't be that bad then?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I would like to know this too as mine is whining its head off too and it does my head in its that loud my we sister thought it was the police lol
    scotland
    The problem is once rebuilt you cant balance the assembly without a special rig, the shaft will likely have wear on it as well as the bearings, and the compressor and turbine blades will almost certainly have a little damage. These things spin at 100,000 + RPM so really have to be spot on.
    I helped a friend replace a problem turbo on a Focus TDCI last year and he sourced a brand new turbo 'cartridge' ie, the main moving parts assembly less the turbine and compressor housings which you take off your old one. £200 if I recall correctly.
    Not sure if this is commonly available for all turbo types though.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Send it off mate get it rebuilt I have a few contacts of ya want me to have a chat with them
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Not worth the bother mate as above could end up damaged afterwards
    Theirs a great turbo place in skem that we use.
    Can get a contact number if you need
  1. Where to buy 1.9cdti 150 hose kits
    By Craig1985 in forum Bodywork & Interior
    Last Post: 30th December 2012, 20:22
  2. can this be used to rebuild my turbo 1.9 sri cdti ?
    By john norris in forum Engine & Drivetrain
    Last Post: 8th September 2012, 07:46
  3. closed induction kits on a turbo car
    By tomo41 in forum Tuning
    Last Post: 13th September 2011, 23:32
  4. 1.9cdti Service Kits
    By alcutler in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:21
  5. Vectra 2.2dti 03 turbo rebuild
    By alphabravo in forum Engine & Drivetrain
    Last Post: 24th June 2009, 15:53
vectra cdti turbo rebuild
vectra 1.9 cdti turbo replacement
vectra c 1.9 cdti turbo repair kit
turbo rebuild astra desil
turbo rebuild 1.9 cdti
vauxhall zafira turbo rebuild
vectra sri 1.9 turbo replacement
astra h 1.9 cdti turbo rebuild
rebuilding a vectra z19dt turbo
vauxhall vectra 1.9 cdti turbo rebuild kits
Vectra C 1.9 cdti 150 brake turbo rebuild
vauxhall insignia cdti turbo repair kit
vectra turbo repair kit
turbo rebuild kit
1.9 cdti turbo fitting kit
turbo repair vectra c
vectra c turbo repair
fitting a turbo cartridge to a cdti vectra
vectra c 1.9 turbo cartridge replacement
vectra turbo repair
1.9cdti engine rebuild
turbo whining vectra 1.9sri
