Results 1 to 10 of 18
Thread: Remapped 2.0t keeps getting boost sensor faults
    Worksop
    Default Remapped 2.0t keeps getting boost sensor faults
    As above keeps losing turbo ie safe mode then comes up with boost sensor fault code turn key on/off and it's back to normal replaced boost sensors no joy any ideas fitted silicone hoses no leaks there and new vac pipes
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    are you using an aftermarket dump valve
    Worksop
    Not anymore nige took it off to see if it stops it but it's still same
    Jun 2009
    South Coast
    What is the fault code? We need more info to work with though matey... Codes are a big help....
    Are you using a modified airbox, standard airbox, cone filter? How long have you been getting this issue, since the pipes were changed? I see you had this before with the aftermarket Dv fitted as well?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Possible overboost mate or spike as Nige said codes would help alot
    Worksop
    I'm getting the boost sensor code can't remember wot it is modded box silicone hoses silicone vac pipes boost gauge stainless system p0234 code no aftermarket dv
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    That's overboost mate have you tryed to lengthen the actuator rod or is it stuck
    South east
    Have you got the two new boost control valves the right way round - they look the same, but they're different so you need to have the correct one next to the turbo and the correct one next to the TB.
    Worksop
    Yeah they right way round will it be ok lengthin actuator arm?
    Jun 2009
    South Coast
    Just try one complete turn at a time and test drive it between each turn. Becareful of the very hot turbo though, it will burn you badly if you're not careful.
  1. Boost on a remapped cdti 120 22psi
    By VCC in forum Diesel Engine related
    Last Post: 2nd January 2013, 23:06
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
