Thread: slight misfire/skip a beat/ between 1500 and 2000 rpm when going up the gears
    Jul 2012
    Ireland
    Default slight misfire/skip a beat/ between 1500 and 2000 rpm when going up the gears
    Ive chnged the clutch and DMF, also had injectors tested and refurbished also cleaned EGR valve ,boost soleniod valve,throttle, and checked all hoses.only thing i can find here to try is no3 wiring injector.i read here somewhere it can be got for 12 pounds.if so where? also is there anything else worth trying.its bugging the $*** out of me.cheers guys peter
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Part number is 93189918, GPS showing them in stock at £8.53, Ebay at around £15, VX around £14.
    http://www.genuinepartsearch.co.uk/v...ck-search.aspx
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by Ruffus2 View Post
    was it doing it before you changed the clutch and dmf
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Jul 2012
    Ireland
    Ye it was. i only had the car 8 weeks.clutch was a bit rattly i was hoping that would sort it.big difference in the car since i got it changed and cleaned all the valves.I only figured out it skips between 1500 and 2000 rmp yesterday.I thought it happened randomly but at this stage i can almost make it skip by driving between these rpms.im gonna try e bay now get new injector wiring loom just for no3.
    Jul 2012
    Ireland
    GPS are saying connector housing.is that what the no3 injector wiring loom is actually called.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    This is what you get with that part number.
    Jul 2012
    Ireland
    Quote Originally Posted by vectra ste View Post
    ye i saw that cheers. i took boost solenoid off and took out the small gauze filter which was very clogged up but didnt replace it.i didnt actually open up the valve as shown because mine doesnt have the metal ring around the black and cream piece.it just seems to be glued/sealed together.maybe i should have.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    what colour is your no3 wiring injector yellow is old
    blue is the upgraded one
    Jul 2012
    Ireland
    ye its yellow,im ordering new blue one now. cheers mate
  1. 1.9 CDTI 8v 1500 rpm MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 26th August 2012, 10:34
  2. 3.2 GSi slight misfire, need help....
    By TimTay in forum Engine & Drivetrain
    Last Post: 19th August 2011, 11:10
  3. hesitation between 1500-2000 rpm
    By doggydoctor in forum Engine & Drivetrain
    Last Post: 28th July 2011, 10:42
