Thread: Vectra VXR 345mm Set-up
    Default Vectra VXR 345mm Set-up
    Right,
    I have everything now to fit these bar the discs (picked up the front pads today). I'm unsure now if I want to fit them due to the increase in un-sprung weight. Will I notice a decrease in the performance of my 2.2 non-direct if I fit these?
    I'm now thinking the 314 set-up may be more suitable!
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The 314mm and 345mm calipers are basically the same so not a lot of difference in unsprung weight if you want increased braking performance over the standard front discs then the 302mm 2.0T ones are a better option, if unsprung weight is your concern, also the rears should be uprated to 292mm IMHO as the 345mm setup will give a different brake balance to the car especially in the wet
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    The discs will weigh more but the 314 and 345 caliper are virtually identical, I can't see them slowing you down that you would notice, but you should make find time under braking
    South east
    Quote Originally Posted by Lean6 View Post
    Right,
    You're confusing two different things, which tells me you're worrying about nothing. Unsprung weight does not slow a car down, because you could compensate for the increase in weight of the brakes by losing weight yourself, or having less fuel on board, or taking the tools out of the boot, etc etc etc. What you're referring to there is kerb weight.
    Unsprung weight is only the weight of the components that are located on the wrong side of the suspension - i.e. the wheels and brakes, because they don't benefit from the suspension effect of the springs. The downside of an increase in unsprung weight is a slight deterioration in handling. However, as your car is highly unlikely to be set up for optimal handling anyway, (i.e. does it have coilovers? Polyurethane bushes all round? The biggest ARB? Semi-slick road-legal tyres?) you won't even be able to notice the difference.
    Thanks for putting my mind at rest guys. Rebellion, I think you're right; I'm confusing un-sprung weight with kerb weight. I'm going to fit coilovers to it soon and I'm also swapping my XP2 wheels for some pro race 1.2's.
    Another thing I didn't think of (don't know how), is the advantage of being able to brake harder and later before corners! I'll continue with the fitting of this brake set-up.
    Thanks to everyone who replied, all good points!
  1. For Sale: Vectra VXR 345mm Calipers, discs and pads
    By paulmac in forum Parts for sale
    Last Post: 11th October 2012, 17:36
  2. 345mm Vectra VXR Brake Upgrade
    By Lean6 in forum Handling & Braking
    Last Post: 8th July 2012, 20:08
  3. 345mm pads
    By dannysport18 in forum Handling & Braking
    Last Post: 13th August 2011, 21:31
  4. HEL part No. for VXR 345mm kit, please.
    By thefibreguy in forum Handling & Braking
    Last Post: 11th June 2010, 00:01
vauxhall insignia vrx 345mm brake
https:www.vectra-c.comforumshowthread.php169626-Vectra-VXR-345mm-Set-up
