Results 1 to 1 of 1
Thread: Signs & Symptoms of a Bad Diesel Fuel Pump
    Lincoln
    Default Signs & Symptoms of a Bad Diesel Fuel Pump
    whats the mains signs think mines knackard car runs fine but when you rev it High-Pitched Sound goes away after a while tho and pain to start loads of air the fuel pipes too after the fuel filter also when you look at the filter its as black as the ace of spades
  1. Signs & Symptoms of a Bad Diesel Fuel Pump
    By Madmarky01 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th August 2012, 21:13
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. diesel fuel pump kaputt
    By onksy in forum Engine & Drivetrain
    Last Post: 3rd April 2007, 07:41
