Results 1 to 10 of 23
Thread: Has my Turbo died? Vectra C 1.9 cdti 150 16v
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    confused Has my Turbo died? Vectra C 1.9 cdti 150 16v
    Hi there everyone,
    Just after some advice. Been out in car today and all was okay until after about half an hour of driving around the car seemed to be sluggish, I had a feeling something was wrong but at the time I was in a built up area in traffic so couldnt be sure.
    When on the open road it became obviously tthe lack of power and up hill car was really struggling, some times having to drop one or two gears.
    Ive been looking at second hand turbos and emailed a local company that reconditions them but before I buy anything expensive is there anything else it could be. I am fairly good with repairs is a replacement a DIY job?
    Thanks in advance
    Tim
    Glasgow
    Its probably not the turbo. More likely one or both of the following: EGR valve, inlet manifold/swirl valves.
    Jul 2011
    United Kingdom
    Check your vacuum pipes one of mine came off not long ago and had the same symptoms as yours cost nawt just stuffed it back on.
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Quote Originally Posted by byebyeitsagsi View Post
    I know my swirl valves are disconnected as the bar was off in the valley for ever and when I did the fix from the forum the EML came on so I took it off again. I've cleaned EGR a couple of times is there anything I should look for?
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Quote Originally Posted by stickygreen View Post
    Where was the vacuum pipe located mate? I can go check now.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    if ya turbos gone there will be lots of smoke also the intercooler pipe will go flat when reved hard
    Jul 2011
    United Kingdom
    At the front between the battery cover and radiator the silver air con pipe,it has two pipes coming off it one gos down behind the and one goes up to the engine and connects to metal pipes and there is another one there just check all the little black pipes it shoud be obvious if one is off.
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    I've just been to look at vacuum pipes and there is one that goes over engine that really small and seems to go from a small meter tube into a larger metal tube, anyway that's just come off in my hand, it seems to have split all down one side. I put a piece of heat shrink on it and tried engine, it ran a bit lumpy then on checking pipe the little bit inserted in the big bit had come apart. Could it be this part? Where can I get something to replace it tomorrow?
    Jul 2011
    United Kingdom
    If you mean the plastic bit that was inside the pipe i just threw it away and stuffed the pipe back on .the orignal pipes are useless uou will have to replace it in time but they are cheap enough.
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Yeah I think that bit, it's all brittle, been reading a thread about this pipe, I don't think it's helping but it seems a bit extreme for it to completely lose all power for a small piece of tube.
  1. Vectra has died, turbo goosed!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 17:52
  2. Turbo Died Vectra 120 8v
    By mani911gt3 in forum Engine & Drivetrain
    Last Post: 16th November 2010, 18:20
  3. vectra 120 cdti engine died suddenly
    By donniecdti in forum Engine & Drivetrain
    Last Post: 20th March 2010, 10:31
  4. Turbo Died Then Resurrected
    By Fearns in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2006, 13:37
vectra 1.9 cdti turbo
vectra c turbo
2007 vauxhall vectra 1.9 cdti turbo
turbo for vauxhall vectra 1.9 cdti
1.9 cdti turbo
where is the turbo on a vectra 1.9 cdti
vauxhall vectra 1.9 cdti 16v smoke uphill
turbo for signum 1.9cdti 07
1.9cdti turbo
1.9 cdti turo replacmentTurbo for 1.9cdti vectravectra c turbo coughvectra 1.9 cdti turbo not workingwheres my turbo on a vectra 1.9cdti turbovectra 1.9 cdti turbo replacement1.9cdti turbo not working properlyvectra c dying turovectra c 1.9 cdti turbo newvectra c 1.9 turbo locationvauxhall vectra 1.9 cdti 150 07 turboturbo 1.9 cdtireplace vectra 1.9 cdti turbovectra c cdti 150 turbovauxhall vectra 1.9 cdti turbo not workingvectra c cdti engine view
