Thread: Is it possible
    Regular Member Gortreck's Avatar
    Sep 2009
    Newcastle Upon Tyne
    Default Is it possible
    Hi All
    I have had a bit of a run of bad luck with my 2.2dti. I had topped the oil up and forgot to put the filler cap on, car had been driven about 80 miles, popped bonnet when i heard a tippety tappety noise,oil every where! Topped it up, noise didnt go, took it to the garage, they flushed out the lifters, did oil change etc. Took it to work and it cut out dropping into second gear to slow down. Wont start, crank turns but theres a nasty clank as it tries to turn over. With the garage again to be investigated.
    If my engine is shot, what i am wanting to know is ..... is it possible to instead of putting a 2.2dti engine back in, to put a 1.9cdti 150 engine in its place?
    Based on what i have described above if anyone could offer some insight to a potential fault too would be appreciated.
    Kind Regards
    Tony
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    to change for a cdti would involve a fair bit of work , including programming ecu's etc .
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    easy job to swap engine try buy and engine with all the electrics and eus
    Sep 2009
    Newcastle Upon Tyne
    Thanks for the replies guys.
    So if i get what you said, as long as i get an engine which has the ECU then i should be able to swap ok? Would anything else need changed? I have the old half canbus system is it?
    Tony
    Sep 2009
    Newcastle Upon Tyne
    Any one know? I am hoping the garage will call me tomorrow with the diagnosis of what is wrong, would like to be in a better position regarding this if possible
    Kind Regards
    Tony
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    You'd be better to just buy a 1.9 cdti 150.
    If you really wanted to do a conversion you would be best off buying a smashed complete car for the parts.
    Sep 2009
    Newcastle Upon Tyne
    Well folks, i got the news from the garage, they took the head off and the damage is too extensive to make a repair an econimically viable choice. So I guess its a new engine
    So The help i need is what is actually required for the swap? I am guessing engine, EGR, Turbo, ECU, what about fuel pump? Does the intercooler still work etc?
    I am calling the garage back at around 3 today so if anyone is around who has the required knowledge, would really appreciate any help you can give
    I know i could just buy a 1.9 cdti 150, only problem is I dont have the spare cash to buy one outright, and i would then have 2 vectra's, one without a working engine :s Which is why i was wondering if it could be "upgraded" in my current car.
    Kind Regards
    Tony
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You would be cheaper getting a low mileage 2.2 engine ! Surely if you did decide to change to cdti you would need new gearbox, engine all wiring and extensive tech2 sessions to code everything to new ecu
    Low mileage units on eBay for around £ 300-£400 easiest option on pocket imho
    Irmscher Insignia CDTI 130
    Aug 2010
    Leeds
    What is the damage cracked head & bent valves or bent con rods?
    Another engine same as less head ache straight swap or new heads.
    Sep 2010
    Surely this would be cheaper than paying all that labour to chop a different engine into your car?
    http://www.autotrader.co.uk/classifi...ge/2?logcode=p
