Thread: Slight oil drip after oil & filter change
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default Slight oil drip after oil & filter change
    Did my first oil & filter change today on my 1.9CDTI 120.
    Despite having rags to hand and a bit of hose on the drain on the filter housing, oil still p***ed everywhere when I took the old filter out.
    Cleaned it up best as I could and put the new filter back in. It went freely at first, but it went semi-tight within a couple of turns, but took a good few minutes of turning by hand (had to give it some effort, mind) and then a nip up with the spanner before I thought it was tight enough.
    Now, I've been out for a drive, come back and found 2 or 3 drips of oil on the exhaust pipe which appears to be coming from the drain on the filter housing.
    Could this still be old oil dripping out? It doesn't look like new oil. Best to wait a few days and check again?
    And should the filter housing have taken that much effort to turn by hand? Should it be easy to turn until it just needs nipping up? Or is that amount of force right? It did take a fair amount of effort (by hand) to get the housing off too.
    Sorry for all the questions, I'm starting to doubt my DIY skills now!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    did you change the filter housing ring seal bud?
    Jul 2009
    Wiltshire, UK
    Yep, both of them. Made sure they were seated properly too.
    Are you VXR Enough
    13 Post(s)
    and you didnt spill any when you refilled the engine?
    Jul 2009
    Wiltshire, UK
    A little. The drip looks more like old oil though (very black).
    I'll keep an eye on it for a few days.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    It could have been dripping out the drain since the change, wouldnt worry bout it, keep an eye on the driveway and check the dippy regularly.
    Yes the rubber seal makes the filter housing tight within a couple of turns, very laborious but it sounds normal.
    HTH
    Stuart
  1. Slight Oil weap - by the filter housing
    Last Post: 4th May 2012, 15:45
  2. slight change
    By shb1988 in forum Quick Photo Album
    Last Post: 15th April 2011, 18:34
  3. Another quick wash and a slight change...
    By John LE in forum Quick Photo Album
    Last Post: 2nd March 2011, 23:04
  4. Slight rattle on gear change?
    By Signum-Steve in forum Engine & Drivetrain
    Last Post: 18th July 2010, 14:32
  5. Another slight change-whats your thought's?
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 16th April 2010, 11:21
