Results 1 to 3 of 3
Thread: N/S sidelight bulb repeatedly blowing - any thoughts why?
    Regular Member Barchettaman's Avatar
    Mar 2007
    Frankfurt, Germany
    Default N/S sidelight bulb repeatedly blowing - any thoughts why?
    I've just swapped the headlights on my 2007 Vectra for LHD ones as I'm reregistering the car here in Germany.
    I'm having no luck, however, with the nearside side light. It blows the bulb instantly.
    Just wondered if this is a known problem and if so is there is a known cure. Where would you guys look for the fault?
    Thanks in advance
    simon
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I would say check the connections and clean them throughly. Make sure all connections are tight too.
    Might make a bit of a difference. I have to go through this with my N/S side light as it eats led bulbs for breakfast.
    From what I remember loose connections could cause a bad earth and blow bulbs. This is only from memory of other posts of this nature.
    I might not be entirely accurate on this though.
    Mar 2007
    Frankfurt, Germany
    Thanks Envy.
    Possibly a daft question, but it isn't my first and definitely won't be my last....
    How do you clean the connectors?
    The bulb socket wires just seem to 'disappear' into the guts of the unit and don't have any real noticeable connectors at the end of them. At least not that I can see.
    I'm really frustrated at the mo and a bit down, got the bumper off, swapped everything out, then checked the new headlight and it started eating bulb filaments. Grr.
    Anyway, cheers all,
    Simon
  1. Sidelight not working but bulb is fine?
    By Drazek in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2012, 11:39
  2. sidelight bulb change
    By bigsteve in forum Insignia car chat
    Last Post: 10th November 2011, 11:22
  3. Indicator Bulb Blowing
    By Stuart_1985 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 13:40
  4. Whats the recomended 501 sidelight bulb ?
    By Steven T Davies-Moss in forum Styling
    Last Post: 9th January 2009, 19:54
  5. sidelight bulb holder
    By msilcocks in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2008, 18:13
