Results 1 to 10 of 21
Thread: Water temp gauge
    Jul 2012
    Orkney Isles
    Default Water temp gauge
    Hi everybody, needing some help with my newly aquired 07 1.8 vectra sri with the Z18XER engine.
    Just after I got the car I noticed that the temp gauge was not going up at all - does move 1 - 2mm when ignition is switched on ! I have renewed the Temp. gauge sender unit - from Vx dealers and last night I installed the new thermostat with housing - all to no avail.
    Anyone had this problem or have any ideas as to what next ?
    Thanks.
    I wouldn't expect it to move until about 10 to 15 minutes after the engine has been running
    It certainly should not move straight after starting the engine from cold
    I would be more concerned if the temperature gauge moves a lot
    Typically, this is a normal reading once the engine is warm, then dropping to cold after a long drive (whilst the engine is still warm)
    This is one of the traits of modern engines, some don't even have a temperature gauge and simply have a warning light
    However, most diesel engines still have a temperature gauge as it is very important (to prevent damage by overheating)
    Jul 2012
    Orkney Isles
    Thanks for the reply but this is after 15 - 20 mins driving - no movement at all. The slight 1 - 2mm movement is just with the ignition - hot or cold engine.
    Quote Originally Posted by obews View Post
    This sounds correct, as any inducted voltage / current will cause movement in most gauges
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Thanks.
    i replaced my thermostat at 53000 miles
    i have the 1.8 it takes around 3 miles to get to 86-90
    say with the outside temperature at 11 degress
    sometimes it goes to 92 and when the fan cuts in it goes back to 86-90
    if it is reading between 70-75 after 20 minutes its broke
    Jul 2012
    Orkney Isles
    Trouble is as I have said - it's not moving at all !!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You can use the secret menu on the HU to see if there is any temp reading at all. Then if there is it might mean the dash temp dial is faulty
    Cannot remember which button to press on the HU to bring up the service menu, doh
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    was it an original gm thermostat you bought
    Jul 2012
    Orkney Isles
    Yes genuine GM part from Vaux-world.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    The thermostat for your engine only comes complete and should cost about 100 pounds as it has an electrically controlled valve incorporated
  1. 2.2 se water pump/ temp gauge problem.
    By james chambers in forum Engine & Drivetrain
    Last Post: 29th June 2012, 20:31
  2. 2.2 se water pump/ temp gauge problem.
    Last Post: 19th January 2012, 02:13
  3. water temp gauge
    By vectra.sri in forum Engine & Drivetrain
    Last Post: 26th August 2011, 00:18
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. temp gauge
    By tobybongo in forum Engine & Drivetrain
    Last Post: 17th October 2008, 21:27
how to install water temperature gauge vectra c
