Thread: 1000db ccr2006!!!!!!
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Default 1000db ccr2006!!!!!!
    I tend to leave my radio on all the time and, obviously it goes off with the ignition when i get out. But sometimes when getting back in and turn on the ignition the ****** thing blares out at full volume!!! Any idea why anyone? The TP setting is off and its defintely not anyone else getting in and doing it!
    Feb 2006
    Dorset
    Can you adjust the volume on level ?
    [Ex]Admin Duncan's Avatar
    Not as such....
    • When switching on, the radio is set to the volume level you last adjusted, if this level did not exceed the factory set basic volume level.
    • If the volume level was higher, the radio is set to it's basic volume level.
    I'm sure other people have had the same problem storey - it sounds familiar. Have a bit of a search and I'm sure you'll find the other threads.
    HTH
    May 2006
    somerset
    Thanks guys. I'll have a looky see.
  1. ccr2006
    By arniedavo in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 04:42
  2. Ccr2006
    By seanyis in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2008, 21:18
  3. Ccr2006
    By Elevonic in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 18:53
