Thread: Fuel Pump
    Regular Member Johnty's Avatar
    Burnley
    Vehicle : Vauxhall Insignia Sri Cdti 2.0 Vx-Line
    Year : 2010
    Smile Fuel Pump
    Hi,
    I've just ordered a new Continental fuel pump for my Vectra Elite 2.2 Direct. Are they easy to fit and is there any special equipment needed to check the vehicle once the pump is fitted? I know that the pump has to be depressurized before commencing work on the fuel system & engine cold, just to be safe.
    The reason that I want to change the pump is because having just had a fuel pressure regulator fitted, I noticed that the fuel pump on my car is the Siemens brand and I've read a lot of bad news about these.
    Regards,
    Paul.
    Burnley
    Year : 2010
    I managed to fit the new Continental fuel pump today without any problems whatsoever. No car/spanner light when I fired her up too. Well chuffed!!
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    not so hard to do is it... I uprated mine when i changed it... Did not see this thread though as its in the chat section for some reason and i don't normally go in here..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Quote Originally Posted by Johnty View Post
    Hi,
    Regards,
    Paul.
    did you see it on watchdog then
    Burnley
    Year : 2010
    Hi Ste. Yes I've seen the Watchdog clip online previous to me fitting the new Continental pump. I have also just had a new fuel pressure regulator fitted as well.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    i found this thread for you to have a read
    sorry if you allready have
    http://www.vectra-c.com/forum/showth...l-engine-fault
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel Pump
    By seanyis in forum Engine & Drivetrain
    Last Post: 6th April 2009, 10:08
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
