Results 1 to 3 of 3
Thread: Light on dash
    Dec 2005
    RUNCORN
    Default Light on dash
    Help anyone. Got a new amber light up on the dash. It is a stearing wheel with a exclamation mark in it
    Ask local Vauxhall dealer about it and he told me it needs to go on there computer. And cost a weeks wages to do so. Then called local independent expert and was told it needs to go on the computer too. But could be a list of things.
    Is there anything it can be or I can try before giving money away just to be told I need to send loads more money
    Any ideas will be welcome. Thanks
    Feb 2011
    Selby
    Well, it's clearly a power steering fault, but you will have to have the fault codes read to find out what. I'd find an independent garage who know Vauxhalls (and hence have the appropriate code reader) to read it. You really shouldn't be paying more than an hour's labour for a garage to read the codes.
    Alternatively ask nicely on here and there's bound to be someone local to you who won't mind reading the codes for you.
    6 Post(s)
    Fault with electrical power steering.
    No good guessing. It needs the fault code(s) reading out to find out why it's on.
    Not sure if the pedal trick will work or not? Info in the how2 section on DIY fault code reading.
    Generally the diagnostic check cost is waved if they do the repair.
  1. light on dash
    By kgb in forum Engine & Drivetrain
    Last Post: 27th January 2011, 21:05
  2. dash light
    By keith1983 in forum General Chat
    Last Post: 10th January 2010, 23:03
  3. Light on on dash what should i do?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 12:54
  4. Light on dash...
    By dankidd in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:13
