Results 1 to 10 of 11
Thread: Whats this bush called?
    Regular Member krazylegz's Avatar
    South Shields
    Default Whats this bush called?
    Does anyone know what this rear bush is called ( under calliper ) as mine is non existent lol
    Sent from my iPhone using my fingers n thumbs
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Lower control arm bush?
    South Shields
    Well I was thinking that but is that not the small banana shaped one to the left of the disc as you look at it?
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Unless there is actually play in the bush I wouldn't worry about it. That same bush looks totally knackered on both my vecs but never caused any problems at mot time. Maybe the outside rubber covering rots away over time but the inner part of the bush still does it's job.
    South Shields
    You can see mine is totally gone mate, the metal inner tube the bolt goes through is touching the metal of the hub
    definately a lower control arm lee
    http://www.opeloem.com/vauxhall/sign...nsion_arm.html
    number 17 is for the arm no listing for the bush
    bush on the bay
    http://www.ebay.co.uk/itm/QH-REAR-CO...item4605f4ecbc
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    South east
    Quote Originally Posted by Handyandy-UK View Post
    No, he wasn't referring to the gold-plated ones that require a mortgage to buy....lol
    May 2012
    Peterborough
    Kate?
    South Shields
    Thanks all
    I couldn't get hold of any bushes today so got two new upper control arms and they seem to have helped a bit, but think the bottom bush still needs changed
  1. whats this called?
    By richje100 in forum Engine & Drivetrain
    Last Post: 15th January 2013, 21:43
  2. Whats it called??
    By kman247 in forum Bodywork & Interior
    Last Post: 11th April 2010, 16:21
  3. Whats this called and where can I get one?
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2009, 10:48
  4. whats it called
    By willoftoon in forum The 'Off Topic' room
    Last Post: 13th July 2008, 19:11
  5. Whats it called? ICE help
    Last Post: 29th May 2006, 23:05
