Thread: Question
    Lincoln
    Default Question
    just a quick one
    where is the fuel going ??
    vectra 2.0 dti wont start if left over night so changed the leak off pipes and fuel filter and put a non return valve plus clear pipe to see where fuel is got up and the clear pipe has no fuel in it where has the fuel gone??
    Dec 2011
    Seaham
    Silly question, did you check the non-return valve was working and installed it in the right way?
    Lincoln
    Quote Originally Posted by Ben50n View Post
    i didnt do it ,mate garage did called the garage said soming about a seal and fuel is leaking into engine oil
    Barrow In Furness, Cumbria
    Injector seals?
    Lincoln
    Quote Originally Posted by Chris SRi View Post
    Injector seals?
    yeah some one eles suggested that too bad ive just took it to the scrap yard got 250 for it
    Was that all that was up with it?
    I'd have given you £251 for it!
    Lincoln
    didnt start when left overnight once started was fine car was doing my head in been like it for a week changed leak off and put a non return valave still same so thougt had enough and scraped it
    Jul 2011
    UK
    Year : 06
    Fuel pump
    Lincoln
    Quote Originally Posted by marc vectra sri View Post
    Fuel pump
    Its gone now fuel cost a bomb any ways
    vauxhall said if it was fuel pump the car would run rough and lumpy the car ran mint once started
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
