Thread: What is this connector in the boot for?
    Jul 2012
    Default What is this connector in the boot for?
    Sorry about the lack of pictures. I'll get one up ASAP if no one can tell from my description!
    In the boot on the right hand side is a flip down panel to change lights, etc. Anyway, while changing my damaged rear light, I noticed a connector wrapped in grey foam. It looks like a mini, plastic ECU connector. Ie, it was (I think) 2X6 way (2 rows of 6 pins) IDC with a flip up lock ontop. There is also 3 threads to bolt something onto. Would this be wiring for a boot changer, Park pilot, etc. or is my car missing something!
    For info, it has a CD70 Nav unit fitted that was, I assume, factory fitted...
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Sounds like the TPMS connection
    Jul 2012
    Spot on! Just Googled it and found a thread describing the exact location! Ooohhhh does that mean a, reasonably, straight forward retrofit if the wirings in place... But I don't need it... But I want it... But... But......
    Jun 2009
    South Coast
    Well it can be, you will need to check behind the wheel arch liner to see if the axle loom has the plugs on the end for the tpms receiver. You will then need tpms sensors fitted to each wheel. If you have them you can retrofit them and get a tech2 session. Module, receivers and sensors are different for halfcan cars but that will not effect you as you have a cd70 so will have a full can car so can fit both. Looms can modified to add the receiver connections.
    So it can be done but it depends on your wallett and how keen you are modding.
    Apr 2011
    Northamptonshire
    Easy job if you have the wiring loom, andy.l can supply the necessary parts.
    Ian
  1. Starter for ten - electrical connector found in boot. What's it for?
    By halster78 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2012, 08:36
  2. Unused Connector in Boot
    By alancallaway in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 07:16
  3. anyone know what this connector is for?
    By trendwarfare in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2010, 07:01
  4. CDC 40 connector
    By unknowngman in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2009, 08:44
  5. What does this connector do?
    By paulw563 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2008, 00:44
