Results 1 to 3 of 3
Thread: Worse job ever ?.......
    Sep 2010
    norfolk
    Default Worse job ever ?.......
    After all other attempts to find and fix my awfull vibration issue, i finally bit the bullet and decided to change the DMF and clutch.
    It is mentioned by others here that this is not a job to be done on your driveway. TBH there right, it was the worse job i've ever attempted....but it's done.
    The old DMF was shot to bits and both sections could be moved by hand independantly. The clutch plate had worn unevenly and the cover had to be cut off as 4 out of 6 bolts had been rounded of by the monkey who last changed it...Also when the gearbox was seperated from the engine the CSC flew apart under its own tension.
    If anybody else considers doing this job at home, it is possible. BUT i would also suggest selling an organ, doing overtime or even something more drastic, and giving it to a mechanic with a lift and the right facillities cos it aint fun.... Also check the weather forcast before you start, laying under a gearbox grunting with rain down your @8&$ing neck just adds to the woes........
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    LOL could of told you that aint the easiest of jobs is it
    Sep 2010
    norfolk
    Thanks for that didn't anticipate that it would be... i've done stuff like this before, but it was on a mini...TBH there was more room to move on the mini, had the previous ?mechanic? not mauled the old bolts the job might have been easier, but i had to remove the GB to get enough clearance to swing a grinder. But heh, now out of wet clothes, showered and fed, cold beer in hand and job now a distant memory.......
  1. White smoke getting worse and worse
    By alphabravo in forum Vectra C / Signum Troubleshooting
    Last Post: 19th March 2011, 01:04
  2. Does this look better - or worse?
    By honigstrauss in forum Styling
    Last Post: 13th October 2009, 23:01
  3. Always someone worse off than you are.
    By SignumPhil in forum The 'Off Topic' room
    Last Post: 9th March 2009, 17:34
  4. Its getting worse..........
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 18:23
  5. Bad to worse!!!!!!!
    By Caterman in forum General Chat
    Last Post: 25th December 2007, 06:52
