Thread: Fitting Astra VXR gear stick on a Vectra C
    Regular Member danny_n's Avatar
    Feb 2011
    wakefield
    Default Fitting Astra VXR gear stick on a Vectra C
    As above, need some help trying to fit an Astra VXR gear stick to my vectra.
    I've been after one for a while and to my understanding if it had the housing below it, it would be an easy swap.
    However I took a punt and bought the following which doesn't have the shaft/ housing;
    Is it possible to fit this to my vectra? If I can manage to get the standard knob off, should this then fit on? Or do I need to buy the shaft/housing from an astra?
    Any advice appreciated
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I would think this would slot right on as there the same as the vectra. when i did mine i split it from the ball and swapped it over from there as i couldn't get it off from where yours is off from as it would have been easier to fit the vectra gator cover that way.
    Feb 2011
    wakefield
    Quote Originally Posted by Mark-R View Post
    right thanks, i'm hoping that if i can get mine off at this point it should be a straight fit
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Would of been alot easier if you had the stick there aswell, pop the old one out and pop the new one in with the balljoint at the bottom, mine has an astra VXR one. I see no reason it wouldn't work this way too, it's just alot of effort to remove the old knob, from memory the astra gaitor doesnt fit properly either.
    Regular Member dave786's Avatar
    Jan 2012
    leeds
    no you need the stick too as the vec stick is longer i just fitted a vxr today takes about 20 mins thers one one ebay with the stick
    Jan 2012
    leeds
    if you need a hand let me know im in morley not far from u
    Feb 2011
    wakefield
    Quote Originally Posted by dave786 View Post
    that's great, thankyou.
    So i definately need the lower section of the stick, wonder if i could source one from a scrapyard off any astra H, if it would work?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    you will need the sri or vxr lower stick as a normal one is about the same size as the vectra stick
    Jan 2012
    leeds
    yea as mark says vxr or sri
    Jul 2011
    UK
    Year : 06
    Can ya not just use ya original stick
  1. Astra gear stick
    By dilan in forum Styling
    Last Post: 19th July 2012, 13:20
  2. My XP2 with Astra gear stick
    By Mopar Man in forum Quick Photo Album
    Last Post: 21st March 2012, 19:51
  3. astra gear stick
    By marc vectra sri in forum Styling
    Last Post: 12th March 2012, 18:24
  4. Will an astra h gear stick fit?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2010, 17:30
  5. Vectra/Astra VXR Gear Stick...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 21:53
vauxhall astra vxr gear knob fit a vectra c
will a astra h gear knob fit a vectra c
how should my gear stick knob fit on a vectra
fitting vxr gearknob
vectra c gearnob removal 2004
fitting of gear knob on vauxhall vectra c vxr 2.8 turbo
vectra vxr gear knob removal
does an insignia gear stick fit a vectra
Vxr gear stick vectra c
