Thread: Air con problem
    Jul 2012
    Default Air con problem
    I went to get air con recharged today and lad says that the compressor is not pulling in the gas Can anyone help. He says it could be a pressure switch.
    Jul 2012
    Can someone help please.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    What exactly do you mean by that ?
    The procedure for re-gassing a/c Is to start with recovering the old gas (if there is any in the system) and oil, then the machine will pull and hold a vacuum (for as long as its been preset normally 10 mins)
    Once that is done and and the a/c system is fine (still holding vacuum) you reload the system with new oil and gas.
    Once the system is gassed and the compressor is running one a/c pipe should be warm/hot and the other should be cold/frosty, if after regassing the compressor doesn't kick in then there may well be a fault with the pressure switch or another componant in the a/c system
    Full Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    6 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    I agree with above post,also i would be using somebody who knows what they are doing--go for an independant car- air-con guy in your area,the one i used was spot on.don't use the likes of kiil-fit/ shagfords etc,they are hopeless----Dave
    Jul 2012
    Hi thanks for the replays. Yeah a tho
    K I'll got to a auto garage. And when I switch the air con on the compressed doesn't click on.
    New Member CBR1000RR's Avatar
    Apr 2011
    Durham
    Quote Originally Posted by dave1419 View Post
    Hi Dave,
    can you tell me who you used, i need mine sorting soon before i go on hls(wishful thinking for hot sunny weather)
    cheers
    Dave
    Jun 2012
    newcastle upon tyne
    6 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Here is his number-07890656586 and his name is Richard. Think he live's in Gateshead-cracking guy and honest too,i got mine repaired under warranty but he pointed me in the right direction. If the repair was not under warranty i would certainly of used him-knows what he is doing ----hope he can help----Dave
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
