Thread: please help
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    confused please help
    Hi all. really struggling with this. could any one tell me what this cables for and part number ( arrowed in blue ) i know its to do with the power steering. my alternator snapped and took this with it. please help.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    sorry for wrong section
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Bump
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Like you say it's the wiring to the power steering. Trace it back into the wiring loom to see if it has a plug at the other end. If it does then you should be able to see a white label around it with a barcode and part number on it. If it disappears into the loom without a plug then it's either a new loom section or cut the out the damaged part and solder in a new section from a loom at a scrapyard. One wire may be the supply cable to the EHPS. It will be really thick so make sure if you join it that its got a proper decent connection as it draws a fair few amps
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    when my alternator went it ripped the wire in half and i dont have any clue were the other part went. i have tryed googling it and been to vauxhall, they dont even know.
    Derbyshire
    6 Post(s)
    Does the plug have 3 wires on it?. Green, black and brown. If it does then it goes to the steering rack. If you look down the bulkhead at the back of the engine where the steering column meets the rack there will be a black plastic plug, this should be where the 3 wires terminate. Just unplug both ends and replace the cable. I have a cable with the green, black and brown wires if you want it.....
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    That's the one mate. How my much you want for it?
    Derbyshire
    6 Post(s)
    Yours for free mate. Just pm me your address and I will stick in the post....
