Results 1 to 10 of 15
Thread: Knocking Noise from Rear - Expert Advice Needed Please
    South east
    Default Knocking Noise from Rear - Expert Advice Needed Please
    I've had a knocking noise coming from the rear of my Signum for two months and I just can't find the cause. It sounds very similar to the noise of the exhaust hitting something, or perhaps the 5"x3" stainless tips hitting the cutouts in the under-bumper skirt, but read on and you'll see it's not that. Itseems to come more from the rear N/S than the O/S. This is what I've tried so far to solve it:
    Exhaust
    1) Removed the bolt-on exhaust tips to see if they were hitting the bumper cutouts. Noise still there.
    2) Got under the car, found middle section of the heat shield hanging down where it had rusted away around the bolt, bolted back with an oversized washer. Noise still there.
    3) Checked all the rubber mounts for the twin back boxes and tied the larger backbox to a bracket on one side to stop it swinging as much (even though it wasn't hitting anything). Noise still there.
    4) Found a bit of the heat shield that was touching the back edge of the wheel arch liner and bent it out of the way. Noise still there.
    5) Further up the exhaust, found the bracket that holds the flexi section to the rubber mounts had rusted off, still connected to the rubbers though, so it could have been hitting the exhaust. Removed it. Noise still there.
    6) Jubilee clip that I'd put around the flexi 4 years ago to stop a rattling noise at low to mid RPM had rusted and was sitting loose on the flexi. Took it off. Noise still there.
    7) Flexi looking a little tired, but not too much, but had a new stainless flexi from MIJ welded in place. Noise still there.
    8) Had a garage look over the entire exhaust, for signs of damage or knocking, they couldn't find anything. Noise still there.
    Suspension
    9) Found that the rear ARB droplinks were looking cracked so replaced them (and wrote a How2). Noise still there.
    10) Outer bushes on the upper control arms were too soft, so replaced them (and checked the inner bushes - they were like new). Noise still there.
    11) Compressed rear N/S spring using Laser compressors and undid outer bolt on lower rear control arm to be able to see the upper and lower rubber spring seats for signs of perishing. All fine. Noise still there.
    12) Replaced the ARB bushes. Noise still there.
    13) Had a garage look over the rear suspension and springs, all intact, wheel movement pronounced as "solid as a rock". Noise still there.
    Boot/Tailgate
    14) Tightened the tailgate latch in case the boot lid was rattling. Noise still there.
    15) Took out everything under the boot floor. Noise still there.
    16) Rear wiper spindle moving just a little when wobbled by hand, so took off the tailgate interior trim hoping to find the wiper motor wobbling around, but it was held very firmly in place. Noise still there.
    17) Rear number plate bouncng up and down on its screws when moved by hand, and screws just spinning when I tried to tighten them, removed number plate and took car for a test drive. Noise still there.
    Brakes
    18) Took out rear brake pads on N/S hoping to find the anti-rattle clip broken or even the pad snapped in two. All fine. Noise still there.
    19) Disk shield wedged against the bottom edge of the rear caliper. Bent it back using pliers. Noise still there.
    I can't think of much else to try, and the noise is getting worse and is almost constant now. The only two things I can think of to try are to check the O/S rear caliper like I did to the N/S (but the sound comes more from the N/S) and try replacing bush after bush in the rear suspension - the ones that hardly anyone ever bothers to replace because they usually don't fail - could be expensive and certainly very time consuming, and probably won't solve the problem.
    Help!
    South east
    Fixed it! After 2 months, I finally found what the cause was. I won't explain here what it was, in case the mod who did nothing more constructive than move my comprehensive and carefully composed thread from the Vectra/Signum chat section (where it would get plenty of views and replies), to this graveyard section (where two men and a dog may have casually glanced at it), needs to know what the result was. Thanks for that.
    If anyone else happens to need to know what the cause was because they have a similar scenario, PM me.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    anti rall bar bushes ??
    South east
    Quote Originally Posted by Mark-R View Post
    Nope, had already tried replacing them.
    Nov 2010
    East Midlands
    Trim : design
    You forgot to take the Kidnap victim out of the boot!
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Loose spare wheel or jack
    Nov 2010
    East Midlands
    Trim : design
    Left a tin in the boot after shopping at Tesco
    South east
    Quote Originally Posted by troutybrown View Post
    Nope, tried that under point 15 in my post above.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Handbrake cable
  1. Knocking noise from rear
    By IrishVectra in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2012, 20:40
  2. knocking noise from rear
    By Lozza in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2012, 18:35
  3. knocking noise at rear
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:54
  4. Knocking noise from rear
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 20:36
  5. Help needed please knocking/banging noise
    By phil67 in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2008, 15:46
vectra c knocking from rear
vauxhall vectra c banging noise
vectra c squeaky rear new brakes
vectra c spare wheel rattling
rear suspension arm outer bushes on vectra c
vectra c rear end knocking
vectra c lower arm noise under braking
rear subframe bushes vauxhall vectra c
vectra c knocking noise from rear
Vauxhall vectra c rattling noise in wheels
vectra c cluncking noise from back is it d bush
vauxhall astra knocking noise rear
vectra c rear clunking noise when reversing
vectra knocking from rear put foot on brakes it stops
vectra c 150 clunking noise from os rear
vectra c rear shock bush knocking
breaking vectra c
vectra c still knocking after rear upper control arms replaced
what is causing thumping noise on rear of vectra c estate
vectra c upper arm squeak
vectra c outer bush knock inner bush creak
vectra c knocking noise from the exhaust
https:www.vectra-c.comforumshowthread.php169465-Knocking-Noise-from-Rear-Expert-Advice-Needed-Please
vectrac est rear suspension
knocking vectra c likely
