Thread: Steering warning light with exclamation mark
    Feb 2011
    Wearside
    Default Steering warning light with exclamation mark
    Hi Guys, been a member for a while but this is my first post. Thought this info may be of use to someone
    I had the steering wheel with exclamation warning light on my dash. Steering was working fine. My car is a 2005 1.9cdti SRI 120. I read the codes with something I bought from the bay and found the following code present:
    C1531 - Steering Angle Sensor System Voltage Circuit High Current
    To cut a long story short, there is a sensor on the bottom of the column where it meets the rack. The electrical connection on this sensor had worked loose. Cleaned it and pushed it back on and warning light is now gone out.
    Lesson learnt is it is not always the cim that is at fault.
    Cost of repair = £18 for the code reader
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    nice one .............that could certainly save members some expense
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    hi bhod73 very good write up there thanks for the info
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Cheers bud will remember that one
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by bhod73 View Post
    Great post...... where about's is the sensor, mate of mine has the same symptoms but doesn't know where to look for it..?
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    That's a great find. Will have to remember that.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Feb 2011
    Wearside
    If you follow the rack in from the drivers side wheel arch, it is a couple of inches up on the column pointing directly towards the wheel arch
    Lancashire
    Trim : XP1
    Mileage : 66000
    Nice one, thanks mate
  1. facelift vec, yellow steering wheel light with exclamation mark on startup
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 16:55
  2. steeringwheel with exclamation mark
    By nadeem69 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 21:00
  3. Steering Wheel with Exclamation Mark and more....... PLEASE HELP
    By Chris R in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2012, 11:06
  4. Steering Wheel/Exclamation Mark
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2011, 21:36
  5. Replies: 7
    Last Post: 22nd December 2006, 23:23
