Thread: Runs like a dream......
    Merseyside
    Default Runs like a dream......
    Well after the DPF issues last week I was getting a bit fed up - but now its been taken out the car is running like a dream now.
    Its smoother, more economical and a lot quieter. All I've done is clean the EGR out (coked solid!!) cleaned the throttle body and cleaned the boost sensor and modded the Swirl valves and it runs like a new motor.
    I'd recommend anyone with the CDTI unit to spend an hour or 2 doing these simple clean up jobs and you will be amazed at the results!!
    Sunny Dartmoor
    Think mine needs doing, i have few niggly issues, a few hesitations here and there and a little bit noisy, glad you sorted yours
    Merseyside
    All it cost me was a can of carb cleaner and a toothbrush.... well it was the Mrs toothbrush actually!!
    Theres a fiddly little blighter of a part under the slam panel that gets clogged up - vacuum supply with a tiny little filter. Whip it off, clean it up and you'll be amazed at what happens. Plus my swirl valve mod is working an absolute treat!!
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Excuse me, what did you made exactly with your swirl valve ?
    West
    If you have gone to the effort to remove dpf... you will be as impressed with blanking the egr
    Regular Member kamar's Avatar
    bradford
    Wot I did was I unplugged the egr and yes it was better to drive. Few days later I plugged it back in but the EML won't go off.
    West
    do you have a code reader? my egr is unplugged & all i do is now & then plug it back in & reset the codes
    Jun 2012
    Edinburgh
    Quote Originally Posted by signum_1.9 View Post
    more details please
    N Ireland
    My DPF was seriously clogged up. The back pressure actually was forcing exhaust fumes out of the flexipipe making it hiss it was that bad. Ran like a complete dog event though you could tell it was still boosting. Took off DPF, drilled a few 10mm holes with a long bit and its running like a charm now. Will probably have to do ongoing maintainance on the egr, boost sensor and boost valve but sure that's no biggie.
  1. my dream car
    By neill in forum The 'Off Topic' room
    Last Post: 23rd February 2011, 00:24
  2. What's your dream car? (that you cant quite afford yet!)
    By sri andy in forum The 'Off Topic' room
    Last Post: 29th September 2009, 23:05
  3. What a wierd Dream
    By Brocks in forum The 'Off Topic' room
    Last Post: 3rd July 2008, 10:27
  4. Boy Racers Dream
    By carl bear in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 10:09
  5. how much dream on
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2007, 19:57
