Thread: Unplug EGR: Top one or bottom one or both
    Jun 2012
    London
    Vehicle : Vectra 1.9 cdti (150)
    Mileage : 105,000
    Default Unplug EGR: Top one or bottom one or both
    Hi,
    Need help.
    Which one shall i unplug. Car had EML on and is in limp mode. Diagnostics show that its the EGR. I have cleaned it and worked well for a bit. Then went back to limp mode.
    Iv taken top plug off (egr) but only small difference. The bottom is the 'electrical one' i was told. Can i/should i take that off too. And hw?? Its hard to take off!
    M
    Nov 2009
    newcastle
    try blanking it to see if any performance change but will leave light on but if it works use a blank with small hole in to stop it?
    Jun 2012
    London
    Mileage : 105,000
    Yes i think i will get it blanked.
    I was told blanking only works on the vacuum type egr valve and not the electrical one. Now the problem is i have not got a clue which one i have! Lol
    I have ordered anyway but will seek advice on weather it will work/fit on my v6 3.0 cdto 2004
    M
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    it is recommended not to do such mods to this engine.
    Jun 2012
    London
    Mileage : 105,000
    Quote Originally Posted by GazCDTI150 View Post
    Right ok - so i shouldnt blank it? Are K&N filters regarded as mods?? Will this be ok to put in k&N filter in my 3.0 V6?
    Cheers,
    M
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mtqn View Post
    Cheers,
    M
    Performance filters personally I wouldn't put in my car as the oil coating you have to put on some of them could potentially break away and damage the MAF. That said however plenty on here have performance filters with no issues - I would say I'm just too paranoid that way.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers,
    M
    Performance filters personally I wouldn't put in my car as the oil coating you have to put on some of them could potentially break away and damage the MAF sensor. That said however plenty on here have performance filters with no issues - I would say I'm just too paranoid that way.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    double post
  1. What happens if I just unplug a suspect bad EGR on a 1.9CDTI 150?
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2012, 09:39
  2. How do u unplug Door switch Connector ???
    By Dal5band in forum Bodywork & Interior
    Last Post: 28th March 2012, 23:19
  3. How do you unplug heater control panel ?
    Last Post: 30th January 2012, 23:14
  4. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
  5. unplug air flow meter
    By monkeyoodle in forum Engine & Drivetrain
    Last Post: 15th February 2011, 06:59
