Thread: Led side light strobing solution ?
    Regular Member Y6 6REG's Avatar
    Mar 2011
    Stafford
    Default Led side light strobing solution ?
    has anyone used these to try and stop the strobing issues ?
    http://www.ebay.co.uk/itm/2-x-LED-WA...item2573a8aae2
    for £12 gotta be worth a shot.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    They won't stop the strobing.
    Mar 2011
    Stafford
    because......??
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It's only a resistance parallel to the bulbs.
    I have 55ohm resistor in parallel an it still doesn't stop it.
    They strobe because internal resistance is very low on led.
    To stop it needs to be a capacitor in series with bulb
    Engine : 1.9 CDTi
    Because the Canbus system sends a quick low voltage pulse to check the condition of the bulbs.
    The cancellers just 'load' the wire so it thinks its got the correct current draw so no errors.
    Bulb errors and strobing are 2 different things.
    Mar 2011
    Stafford
    cheers for that, thought i'd found a quick easy fix
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    easiest way is to use the spare illumination wire near gear stick and run in some new cable for your led side lights
  1. strobing led's
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2017, 22:44
  2. Strobing LED's
    By rmg1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 21:10
  3. strobing interior lights
    By farley2708 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 20:31
  4. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
how to stop strobing of led side lights
solution strobing led opel
