Thread: emissions warning light on constantly.
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default emissions warning light on constantly.
    Hi people. I hope I have posted this in the correct thread section, if not then I apologise!!
    I have got a 2006 Vectra SRi 2.2direct petrol.
    On my last few journeys in the car the emissions light (the engine light in bottom right hand corner, NOT the car with spanner light) has been on with engine running. I have been speaking to some guys from work and they reckon it is because I have used different fuels. I normally use Shell FuelSave but 2 weeks ago I put some Tesco fuel in as that was cheaper. This emission light has been on since the day after I put the Tesco petrol in. People have told me I have put ''dirty'' fuel in.
    I presume they mean crap from the bottom of the tank has got into my car?? Either way I have not managed to get this light to go out and it stays on with engine running. Today when starting the car, the car/spanner light flashed 3 times then the engine cut out. I started it again a few minutes after and the car/spanner light did not show again.
    Any ideas what is causing the emissions light to stay on??? I must also mention that there is a horrible smell from exhaust, almost like a stink bomb!!
    Any info much appreciated as normal!!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    you really need to get the codes read first
    Quote Originally Posted by Casper85 View Post
    Normally the Emissions Warning light suggests the EGR Valve has failed
    However as you have noticed a smell of Hydrogen Sulphide (rotten eggs) this suggests the Lambda Sensor is reporting the Catalytic Convertor has failed or the baffles within the exhaust have failed (usually in the centre section) and clogged the exhaust system
    Equally, if the Emissions Warning Light is flashing, you should NOT drive the car and switch the engine off
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    Thanks for the info.
    I am aware about not driving with flashing emissions light. The car is having diagostics check on Monday morning at my local garage so will post any findings. I need to use the car on Saturday but apart from that it will be parked up. Hopefully nothing serious!!
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    don't know if it is linked but the light went out today with engine running temp at 85. But when stationary temp went up to 93 and light came back on. Cooling fan kicked in at 93 also.
    Feb 2011
    Selby
    Emissions warning light can come on for dozens of reasons. A failing cam angle sensor for example will put it on. Basically anything that means the engine management can still run the engine, but it might not be able to run it properly without risking exceeding the emissions limits. If it's flashing then it means a more serious fault that could damage the catalytic converter, and you should as said above stop driving as soon as it's safe to do so (ie pull off the road and call the AA/RAC).
    You need to read the fault codes to find out what's wrong, otherwise the fault could possibly lead to damage.
  1. Emissions warning light on
    By peterb11 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 17:03
  2. Airbag warning light constantly on
    By Winty in forum Bodywork & Interior
    Last Post: 18th February 2011, 15:11
  3. Emissions Warning Light
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2010, 21:12
  4. Emissions Warning Light
    Last Post: 28th August 2010, 19:23
  5. Emissions warning light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 21:19
vauxhall vectra emissions warning light
vectra c engine emissions warning light
vectra c engine fault light on site:www.vectra-c.com
vectra c exhaust warning light
vauxhall vectra exhaust gases light
vauxhall vectra sri 2009 intermittent emissions light showing
vectra c emissions warning light
2.2 vecra c engine light on
emissions warning light on js series11 vectra
Vectra emissions light
emissions light on vectra c
emissions light on vauxhall insignia
vauxhall vectra c all warning lights constantly on
vauxhall vectra c emissions warning light
can i still drive my vectra cdtdi with the emissions warning light on
