Thread: a question for renault experts re front brakes lol
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default a question for renault experts re front brakes lol
    wrong forum i know but was out in my wee mums clio earlier and brake pads are goosed! can anyone advise me if its a straight forward job to replace front brake pads on ?06 plate clio 1.2 campus?
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Yes really easy job
    Be ware that even tho it's on an 06 plate being a campus it's probably got the mk2 brakes.
    Youll need a 7mm Allen key to do the calipers bolts
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by Critch View Post
    Yes really easy job
    ah good stuff mate ill have s go ,was just a bit wary as my toolkit is basic to say the least lol
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If its only the pads your changing all need to do is
    Jack it up an support it
    Remove wheels
    Remove rubber bungs from end of caliper sliders
    unclip wear indicator plug of fitted
    Undo the 7mm bolt which also acts as the slider
    move caliper out the way
    swap pads over
    carefully push piston back.( I tend to just put hammer handle into piston an then push against my shoulder)
    clean up sliders
    Rebuild
    Tools needed should only be
    Wheel brace
    jack and axle stands
    hammer, g clamp or similar to push piston back
    7mm Allen key
    Hope that helps
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Remove wheels
    Remove rubber bungs from end of caliper sliderss
    swap pads over
    clean up sliders
    Rebuild
    Wheel brace
    7mm Allen key
    Hope that helps
    spot on mate cheers,was wondering if i required rewind tool but clio of this vintage is obviously pretty basic lol
    Engine : 1.9 CDTi
    Front brake pads never need the tool to wind them back.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Only require rewind tool on rear calipers mate.
    All a rewind tool does it make life bit easier pushing them back.
    Rear brakes on the clio a **** lol
  1. Question for the oil experts.
    By Johnsdutton in forum General Chat
    Last Post: 8th June 2012, 10:22
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. brakes question
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 10:08
  4. Quick Question Brakes
    By DarylAAS in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 16:45
  5. Question for DSLR experts, if we have any.
    By 67688c in forum The 'Off Topic' room
    Last Post: 2nd May 2010, 07:48
