Thread: factory cross overs - location?
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Default factory cross overs - location?
    Hey chaps,
    I just picked up a set of infinity Components for the front doors so I will be replacing the factory speakers, tweeters and crossovers. I had already upgraded the door speakers with some kickers but these were a real BARGAIN!
    So, simple question - where is the factory crossover located or are the signals split at source?
    (If so, how should I wire up the components?)
    This is all running off my JVC headunit by the way
    Thanks fellas!
    Engine : 1.9 CDTi
    Normally the tweeters just have caps on them
    Jan 2012
    Essex
    Quote Originally Posted by lee gsi View Post
    Not sure I understand Lee, sorry
    Just looking at the How2 for components and the poster used the signal to the main (mid) door speaker as the input to his crossovers.
    http://www.vectra-c.com/forum/showth...rs-front-doors
    But I wonder where the feed to the factory tweeters comes from?
    If the treble is already split out to the tweeters, then using the input to the larger (mid) speaker wont give the correct output......... or am I over complicating things?
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    If your fitting aftermarket components its best to run them from a amp and replace the factory wiring for 16 or 18awg, you can feed them from the headunit with the factory wiring but you wont benifit that much tbh.
    Jan 2012
    Essex
    Quote Originally Posted by cliomjh 102 View Post
    I had already thought briefly about going direct to the amp (currently runs my sub) or to the head - and I think you are right its an opportunity to upgrade the wires too - top idea!
  1. coil overs, lowing springs etc etc
    By 06sri in forum Suspension, Wheels & Brakes
    Last Post: 25th October 2012, 19:17
  2. Coil overs or springs
    By steve_c in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 18:27
  3. F.A.O peeps with coil overs..
    By hagga in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 18:25
  4. correct wat to fit rear coil overs???
    Last Post: 3rd July 2010, 20:37
  5. coil overs
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 20:58
