Results 1 to 10 of 13
Thread: P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    Regular Member Mark1892's Avatar
    North East
    Unhappy P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    Have now got the following code on my 2003 1.8 - P0141-04 O2 SENSOR HEATER CIRCUIT OPEN (BANK 1 SENSOR 2)
    Is this a fault with the rear O2/Lambda sensor in the exhaust just before the Cat?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    well i thought it fixed itself
    ive found this
    have a look at post 3
    http://www.vectra-c.com/forum/showth...%28BANK+SENSOR
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    also found this post
    update on my p0141 , read code with a u480 code reader , checked no2 O2 sensor with my multi meter and found no continuity on heater circuit the 2 white wires , rang pentagon vauxhall for the price of a new sensor £120 rang local breaker £40 , went on car parts connexion £43 from nidd vale motors (to good to be true I thought ) rang them up new genuine part , arrived yesterday fitted today , have driven my car for 50 miles so far no light and no code on reader
    North East
    Cheers Ste, not sure whats going on. don't know if this has just come on after the exhaust being changed, whether they have damaged the wiring while changing it or knocked it while trying to get it out of old pipe , I will have to have a look. Old code disappeared for a few days but now getting the P0141 and P0170 Fuel trim malfunction. Swapped the front O2 sensor and Maf and coil pack with my mates, cleared codes inbetween each changeover but fault still returned. Sensor 2 must be the rear one???
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    oh you mean when they did the flexi pipe
    North East
    yes mate, cant recall seing that code before, will have to check the logs.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    pm you instead
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by Mark1892 View Post
    as you say perhaps they knocked a wire and its loose
    North East
    Sensor changed and running perfect, with a lot more pick up and acceleration, fingers crossed again
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    excellent news was it the one on the flexi pipe
  1. Replies: 5
    Last Post: 3rd January 2013, 21:56
  2. Replies: 3
    Last Post: 13th August 2012, 22:25
  3. p0335 crankshaft sensor open circuit
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 28th July 2010, 11:52
  4. Oxygen Sensor Heater Circuit Voltages?
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:28
  5. What is P0036 - HO2S Heater Control Circuit (Bank 1 Sensor 2)
    By cjhawker in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2009, 19:00
p0141 vauxhall
vectra c o2 sensor bank 1 sensor 2
vauxhall zafira o2 sensor bank 1 sensor 2
2008 zafira fault code P0141-00 O2 sensor heating circuit malfunction (bank 1 sensor 2)
Opel P0141
Vauxhall P0141
corsa d lambda sensor location bank 1 sensor 2
corsa vxr 02 sensor bank 1 location
vauxhall corsa bank 1 sensor 2
corsa c oxygen sensor2 location
Vauxhall DTC P0141-00
corsa d heater control circuit bank 1 sensor 2
fault code p0141 vauxhall
what one is Bank 1 sensor 2 on corsa
vauxhall corsa d 2011 1.3 cdti code oxygen sensor 1
02 sensor bank 1 vectra c
021 bank sensor vectra 05
corsa c lambda sensor 2 location
vectra 02 sensor 2
sensor heater circuit bank 1 sensor 2 vauxhall
vauxhall p014100
corsa lambda sensor bank 1 sensor 2
Vauxhall DTC P0141-02
corsa codes PO141-8
