Thread: Bonded ribbons
    Jul 2012
    Doncaster
    Default Bonded ribbons
    Hi does anyone know what's needed to remove a bonded ribbon from a pcb?
    Cheers Dan
    Jul 2012
    Doncaster
    Does anyone think as daft as It may sound, could I bridge the very small hole by stapling the ribbon then taping behind and using conductive paint then taping this side?Cheers Dan
    Dec 2011
    Seaham
    Ribbon cables are normally soldered on or have a special connector on the ends of them that clip onto the pcb. I think if you use a staple, you might make another break in the cable as the wires are very thin.
    I would suggest a new cable.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Assuming you've done what I think you may have done if you're talking about the ribbon cables on the dashboard clocks (which are extremely sensitive to hot soldering irons being even close to them and are not soldered and do not have plugs on them). I can tell you that having looked around about this ages ago, there are companies out there which will replace them for you, but it takes very specialist kit and they tend to charge a small fortune for it.
    The ribbons are conductive plastic there is no metal in them at all (hence why they just melt when they get too hot) and they are heat bonded on with a special conductive heated glue.
    I stuffed one of the ribbons on my dash once and it was cheaper to buy a new set of clocks in the long run...
    Jul 2012
    Doncaster
    Hi Ian yes you are totally correct and I was just thinking of trying to temperally fix the problem for a little while aswork is slow at the minute due to the Olympics so didn't want to buy a new set yet!
    Cheers Dan
  1. Interior, Roof Lining and Ribbons
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2012, 00:03
  2. Just bonded my swirl flaps open!
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 10th June 2012, 21:40
  3. Changing light ribbons.
    Last Post: 15th April 2012, 14:10
  4. Electrical Ribbons - Are they expensive?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2009, 23:50
  5. Is the tailgate glass bonded in?
    By John LE in forum Bodywork & Interior
    Last Post: 30th July 2009, 17:16
