Results 1 to 10 of 11
Thread: VXR Sway bars
    New Member MBfromCTUSA's Avatar
    Jul 2012
    Connecticut, USA
    Default VXR Sway bars
    Sorry, new and I can't seem to find anything using the search function. What were the upgrades on the VXR compared to the regular Vectra? I know the brakes were bigger but it had to have maybe lowering springs and bigger sway bars? Are they available?
    South east
    The anti roll bars are simply the larger size ones, the same as on many other Vectras. They do have two-piece bushes though, whereas most Vectras have one-piece ones.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Quote Originally Posted by Rebellion View Post
    Most facelift SRIs have the 2 peice bushes
    Jul 2012
    Connecticut, USA
    What would be the size of the sway bars (mm)? Who carries them?
    South east
    Before you go buying a new sway bar, you need to be aware that to remove the existing one and fit the new one you have to remove the subframe, and realigning it afterwards isn't an easy job.
    South east
    Quote Originally Posted by XPCobra View Post
    You've really helped the OP out with his queries there....
    Jul 2012
    Connecticut, USA
    I've done far more work than that but I appreciate the heads up. I'm in no rush I was just curious as to what is available. It handles well enough now and if I put springs in it the handling will improve to probably more than I need.
    Jul 2012
    Connecticut, USA
    Has anyone measured the thickness of their sway bars??
    The largest diameter bars listed by Vauxhall/Opel for European Spec
    Vectra C are: Front - 25.2mm and Rear 19mm
    South east
    Quote Originally Posted by MBfromCTUSA View Post
    That's a common combination over here, it's not just VXRs that have the larger size ones fitted. I'm sure many people have resorted to measuring their sway bars, because when you want to buy replacement bushes the dealers can't tell you what size you need, you need to either measure the bar or try and find the size or part number written on the bush that's already fitted to the car.
    Jul 2012
    Connecticut, USA
    Which models came with the bigger sway bars? I guess I should measure mine to make sure i don't already have them.
  1. Back end. Sway??u
    By daddy5times in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2013, 20:16
  2. Rear anti sway bar?
    By bedo13 in forum Handling & Braking
    Last Post: 16th October 2010, 19:04
  3. Tow Bars
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2009, 20:22
  4. Rear Sway Bars
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 9th June 2009, 15:39
  5. Tow bars and mot
    By Gr4eme in forum General Chat
    Last Post: 28th April 2009, 12:47
