Results 1 to 10 of 16
Thread: turn signal
    Banned for Being a Numpty
    Jun 2012
    Default turn signal
    when i turn the indicator left or right it turns off after 3-4 clicks any one know if its normal or what really annoying me aarrggghhhh
    It works in two ways.
    Lane change - when you press it lightly one way or the other, then it will give 3 to 4 flashes and self cancel.
    On, and stay on until you either self cancel or rotate the steering wheel, like normal indicators - you have to press the stalk firmly up or down (depending on which way you want to indicate)
    If you want to cancel the indicators, some people make the mistake of flicking the stalk the other way. The best method is to lightly flick the stalk in the same direction you're indicating at the time. That way if you're too heavy handed you won't put the other side on when trying to cancel.
    Full Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    6 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Yepp,mine works in the same way as Big Dave's--nowt to worr y about----Dave
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    Quote Originally Posted by vectraross View Post
    its normal mate
    Jun 2012
    very weird,ive been making that mistake by trying to cancel lol,need to turn the volume up on the indicators is it possible on my 06 sri?
    No option to change volume that I'm aware of. If there was, then I'm sure it would have been posted by now.
    Indicators no more wierd than on the BMW and other car manufactuers that use this set up. Once you get used to them, going back to traditional ones seems very 90's.
    Jun 2012
    lol yeah,...i see a video sumwer of holding indicator stalk and wiper stalk pull n hold forward and it shows a load of options on different things? ill try n find it
    Jul 2009
    Yorkshire
    The Veccy/Siggy indicators are a real pain in the rington! I get sick of them self cancelling etc. Has anybody been clever enough to retro fit 'proper' indicators/wipers stalks? Now that would be a cool mod!
    Jun 2012
    that would be better
    That'll be for the Corsa, IIRC.
    Doesn't work on the Vectra.
  1. Turn Signal Lamp/Indicator Warning
    By Nimbus in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 23:58
  2. where can i get an RPM signal?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2011, 18:00
  3. How can I replace the front turn signal bulbs?
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2010, 12:49
  4. How to remove turn signal stalk
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 16:58
  5. 04 vectra turn signal problem
    By azn_007 in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2007, 22:43
