Thread: speedo change
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default speedo change
    if i fitted 160mph clocks to instead of my faulty 140mph clocks would there be any problems with the difference?
    Jul 2012
    Scottish borders
    also the seller says the clocks have been cleared by tech2
    what does that mean?
    Full Member
    South West
    Dont know what particular car you have, and if it will make a difference, but i bought a set of VXR dials for my Vectra C Facelift, once fitted they worked fine - even the dial sweep on start up. No idea if they were Tech 2 cleared (some components need to be cleared of codes from the donor car before they will work in a different one - ie Tech2 Cleared).
    One thing to be aware of, if you do get a new set of clocks, the milage on the old clocks will still show (and increase) when you fit them into your car. There are places where you can have the milage changed, but be warned any reputable place will need solid proof that you are doing this for a good reason, and not to "diddle" the milage of the car... but the ECU also keeps a track of the milage, so even if your clocks say one figure, the ECU will always have the true milage.
    Jul 2012
    Scottish borders
    yeah i know about the mileage, im just hoping i can plug them straight in i dont have tech2 but do have opcom
    Jul 2012
    Scottish borders
    Will they plug straight in even though they have been cleared by tech2?
  1. Speedo Change
    By 11mallard in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2013, 23:35
  2. Speedo change
    Last Post: 8th July 2012, 20:57
  3. Speedo change
    By Moysha in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2012, 10:25
  4. Change of wheels - calibrate speedo?
    By cossie in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2012, 17:22
  5. speedo change
    By d8mof in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 21:44
what does tech 2 cleared mean
