Thread: help needed with front parking sensor wiring
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    confused help needed with front parking sensor wiring
    hi at the weekend i fitted some front parking sensors which i connected to an ignition controlled live feed from the fusebox,but what i want is for them to turn off when reverse gear is selected and back on in forward gears. i did think about fitting some sort of switch that is only activated in first gear but dont know how to do it. cheers
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    to get that m8 then you have to go the factory fit system
    unless there`s anything else on the market that you can use
    Jan 2012
    wales
    i did think about taking a live of the reversing lights to activate a relay to turn the front sensors off but not sure if it will work?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Only way would be relay controlled.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    I bought the generic kit off ebay, the rears are wired into the reverse lights so are only active when in reverse. The fronts are wired into an ignition live without a switch, they only activate when you come into proximity i.e.- just over a meter away.
    Its all controlled from one control module hidden away in the boot.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    my elite has the factory fitted sensors & the front ones do still work when in reverse , would think they are meant to or you could potentially hit something when reversing into a space & swinging the front end back in .
    Jan 2012
    wales
    Cheers will get a relay and have a fiddle
    Jan 2012
    wales
    Well finaly sorted it bought a micro switch from maplins and made a bracket So it is activated when I put the gearstick in first turning the front sensors on well chuffed .
    Jan 2012
    wales
    Quote Originally Posted by montyfert View Post
  1. front parking sensor switch
    By nokiaman1978 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 00:24
  2. Sports Tourer parking sensor wiring
    By FinnRolo in forum Insignia car chat
    Last Post: 25th April 2011, 06:21
  3. parking sensor wiring
    By daznsaz in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2006, 12:10
