Thread: Any ideas please.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    confused Any ideas please.
    Fitted a Blaupunkt head unit with a steering wheel interface, but i have a strange problem,the wheel controls work fine with the ignition on or off until i start the car then they stop working!.I've tried the turning the stereo off then starting ,a new ignition feed,a new interface and even a new stereo (different type)and still no joy, what am i missing?, no feeds or earths seem to be dropping out and its doing my head in,PLEASE any ideas?.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    could be the can bus mesages when the enigne is running are upseting the switch controls ..............
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    yeah, when i was checking the wires i got 4.5v so it could be canbus (its a '03),any way of tricking it into thinking the engine is off?.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Bleep bleep can-bus any ideas anyone?.
    Feb 2006
    Dorset
    Talk to the manufactuer of the kit , can bus is a PITA could be a faulty unit you have
    Regular Member Orka The Porka's Avatar
    Oct 2006
    North Rochford (The Posh End)
    There is a can-bus interface adapter you can buy. That would make it work for definate. Don't ask Halfrauds though they'll look at you blankly. look for www.celsusice.co.uk if you phone up speak to paul he's top daddy on canbus. Tell him Tom from Southend told you to call him.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Thanks Orka i'll give them a bell tomorrow,do you know if they're expensive?.Blaupunkt couldn't be more helpful,i spent 2hrs one day with one of the technical bods trying different combinations of headunit and interface this combination worked then 99%, ordered one in,works 0% when the engines running!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Just fitted an autoleads PC99-X45 adapter,it works!.Brought it from car audio plus for £41 inc p&p,a tip for anyone else, it comes configured without an ignition feed (added one) so the key won't control the stereo, minor point though.
    Sep 2009
    north lanarkshire
    Quote Originally Posted by tyreman View Post
    hi bud im having same problem were did you take ignition feed from. did you join it to the red bullet connection.did you have to plug the yellow feed in to the main radio adaptor to keep memory
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
