Results 1 to 10 of 11
Thread: Where to get the Clutch replaced?
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Where to get the Clutch replaced?
    Hi,
    I don't know where to go to have my complete clutch system replaced. A local garage or a so called 'clutch specialist' if there are any near me. I thought of Mr Clutch, until i read bad reviews about them, seems like that place is a bit like kwit fit lol.
    I quite fancy buying a performance clutch kit myself and have it fitted somewhere.
    Been looking at these kits
    http://www.ebay.co.uk/itm/VAUXHALL-V...item3cc65b9284
    http://www.ebay.co.uk/itm/3-PEICE-CL...item415b34a0b9
    http://www.sachsperformance.com/Sach...-Kit::334.html
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Its a very common job for virtually all garages, so if you have any trustworthy ones local to you then they will do, doesn't have to be a "specialist".
    Not so sure about solid flywheels for the CDTi, I am sure I read some owners after having them fitted noted quite harsh vibrations, which is to be expected to be honest.
    Jun 2011
    kent
    i have heard you need to get the DMF and Clutch replaced together. and if you get a single conversion you get issues. i fleet of taxis i know had this done to vec/mondeos and they all failed within 6months, and went back to DMF and clutch.
    thats just what i know
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by webtrawler View Post
    It's a complete clutch kit, not just a conversion. Flywheel, Clutch, CSC.
    Lancashire
    Trim : XP1
    Mileage : 66000
    This isn't strictly the case, you only need to change the DMF if there is excessive play - some say do at the same time as the gearbox is out already (save labour costs ultimately).
    Jun 2011
    kent
    oh right ok, i see where your coming from. is there anyway of seeing if there is any play without taking it out?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Not really, only by the noise it may be making.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have the sachs uprated one and 206 bhp and 360lb of torque and have no issues with it. You need a to push a bit more on the clutch but you can change gears quicker. I think my car had the uprated clutch fitted before anyone else went down this route and its still going strong
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by merikiito View Post
    How much was it for the kit with delivery?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by hothatch View Post
    I cannot remember as its been fitted for well over a year now, maybe £550
  1. Clutch and dmf replaced :)
    By nige87 in forum Engine & Drivetrain
    Last Post: 13th June 2012, 20:13
  2. 3.2 clutch slipping so being replaced, flywheel options?
    By merge in forum Engine & Drivetrain
    Last Post: 28th May 2011, 16:20
  3. clutch replaced but now extreme banging!!
    By Jow20 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2011, 13:44
  4. Replies: 31
    Last Post: 18th January 2010, 18:12
  5. DMF + Clutch replaced, now loss of power
    By yzf1kr in forum Engine & Drivetrain
    Last Post: 28th July 2009, 21:07
