Thread: Fan only working on 4
    Jul 2011
    Leeds
    Post Fan only working on 4
    Hi All,
    Fan was only working on 4 in dec, had the pollen filter changed air duct cleaned out, sh blower motor and mechanic soldered resistor onto pack, which he shouldn't have done but hay! He said it could start working when the electricals dry out as was also having problems with electric windows. 7month on still not working, windows are hit and missed and its really annoying as its hard to have a conversation when you have the sound of a jumbo jet in between you! Any ideas to fix, as had opcom on it but not showing any errors just when fan on 1-3 not active and 4 active?
    lincolnshire
    usually cured by fitting a new resisitor , which are pulg in
    11 Post(s)
    Quote Originally Posted by bembo449 View Post
    Or change the thermal fuse for a few pence from Maplin.
    http://www.vectra-c.com/forum/showth...=1#post1495923
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    did the windows stop working when the heater settings broke?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    [QUOTE=shiver2k11;1862406]Hi All,
    Cheers[/QUOT
    see if this helps with your electric windows
    http://www.vectra-c.com/forum/showth...-Window-Switch
    and get a new resistor pack as well
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    it will deffo be heater resisitor pack and dirty contacts for you window switches
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
