Thread: N/side wing removal
    Coventry
    Default N/side wing removal
    Hi all
    Looking to replace the N/side front wing as someone damaged it then drove off.
    Ive read through a guide on bumper removal so im pretty sorted there but need some help with the wing.
    Ive been looking round it for the past 20mins trying to get an idea of whats involved.
    So far its looks like I need to remove N/side plastic skirt, inner plastic wheel arch and the front headlight to gain access to all the wing fixings.
    Does this sound about right?
    Cheers!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Yeah that's it remember theirs a bolt just inside the wing from the door side
    Sunny Dartmoor
    Don't have to remove the wheel arch liner, shouldn't take too long once bumper and skirt are off, good luck
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Yeah Side Skirt needs to come off too.
    Coventry
    Quote Originally Posted by glenboy View Post
    Im sure you do glenboy (ok maybe not remove, but pull if down)cause as you look below the A post there is a fixing which comes through from inside the liner??
    Thx guys
    Coventry
    Hi all, started this morning at 7 got finished at 9.
    overall it is a pretty straight forward job once you know where and which fixings are envolved.
    To be honest the hardest part was pulling the 4 plastic rivets from underneath ( they got slightly mangled but are still useable)
    Glenboy was correct you don't need to pull the wheel arch liner out just manipulate it enough so you can get to fixing and disconnect the wing flasher so no jack or wheel off required.
    Thx to everyone's input and big dave for pointing me in the right direction regarding bumper removal!!
    Thx a lot guys! :-)
    Ive taken some pics if anyone requires more info.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    I did mine recently the side skirts is the hardest part lol
  1. Help wing removal
    By QUIRKY in forum Body & Body Equipment
    Last Post: 14th March 2011, 18:54
  2. wing mirror cover removal
    By booker413 in forum Bodywork & Interior
    Last Post: 29th August 2010, 21:17
  3. Wing removal , pre facelift ?
    By poves in forum Bodywork & Interior
    Last Post: 6th January 2009, 23:56
  4. Wing Mirror Removal
    By curly in forum Bodywork & Interior
    Last Post: 1st December 2006, 16:20
  5. How to fit a driver side wing
    By 111 in forum Bodywork & Interior
    Last Post: 20th October 2006, 17:18
vauxhall signum front wing removal
removal vectra passenger side front wing www.vectra-c.com
how to replace front wing on vectra c
fitting front wing to 2006 vectra
how to remove vauxhall signum drivers front wing
