Results 1 to 10 of 20
Thread: What brake pads
    Oct 2010
    Stevenage
    Default What brake pads
    Can some one please help me, i need to get some new rear brake pads but there seems to be a couple of sizes, i dont want to end up ordering the wrong ones. My cars a 2003 2.2 16v sri.
    Thanks guys
    South east
    It's really not very hard to find the information if you look in the brakes section and see the sticky thread:
    http://www.vectra-c.com/forum/showth...mparison-Chart
    Jul 2011
    edinburgh
    My advice would be only buy genuine GM pads - I fitted 3 different pads (pattern parts) and all rattled like nothing on earth!
    11 Post(s)
    Chances are, if the pads need replacing, so do the discs. Pads these days are made from as hard a material as the discs and can wear at the same rate.
    It can also be false economy to just buy pads when a brake kit works out cheaper than buying the discs and pads separately.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Total rubbish mate, most discs last at least 2-3 pad changes especially on the rear
    11 Post(s)
    Quote Originally Posted by Mr Owens View Post
    Total rubbish mate
    So politely put!
    Mine didn't. The discs were worn to almost their min thickness at first pad change. Also, when I changed the front pads, the discs would have been below their min thickness before they would need changing again.
    As I previously said - false economy. Not to mention the hazzard of getting brake fade if the discs are worn.
    Pricing up rear discs on their own, then pricing up rear discs and pads
    REAR DISCS Approx £40 + vat
    REAR DISCS AND PADS Approx £51 + vat
    Can you buy rear OEM pads for £11 (+ vat) on their own?
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I'm sorry but in the last 14 years as a mechanic I've changed thousands of sets of brakes and very rarely do the discs need changing everytime the pads are changed unless the driver has been realy hard on the brakes
    Regular Member CBR600FV's Avatar
    Wales
    Thats a bit harsh on a fellow member. Modern vehicles with pad material without asbestos do appear to be harsher on disc material and do wear the discs quicker. As you've only been a mechanic for 14 years then you might not appreciate that. Just to throw my bit in, we have 2 Vectra estates in the family, they both wear their rear pads out far quicker than the fronts possibly due to pressure proportioning/rear loading. Just had the front pads changed on one at 75k, original pads with plenty of life left. Had the discs changed as well as didn't think they'd last to the next change. For the price of replacement discs I don't think its worth not changing them.
    changed
    Regular Member Pete B's Avatar
    Malvern
    Yes, definitely false economy, especially if you plan keeping the car for a long time. I've never not changed discs (or drums where used) at the same time as pads (or shoes) on any of my cars since 1998 when observing for the first time how much faster the discs or shoes wore with then new asbestos free friction material than before.
    I've just done a complete pad/disc change on my current car at 65k miles and the discs, although possibly just about OK now would not last another 65k miles or so. It was exactly the same when I changed them on my previous car, a Vectra C at the same mileage just over 12 months ago.
    Not only that but worn discs/drums with modern friction material (which contain iron based materials amongst other things, just like the disc/drum material) are left with a much rougher surface than when asbestos based friction materials were used. New pads have to bed into this rough surface where old discs are being re-used so subsequent pad lifetime will be less, not to mention potential brake performance in emergency conditions during the bedding in period.
    Aug 2010
    Leeds
    Replaced rear pads at 21k as worn low to same thickness as metal backing , but discs in very good condition.
    Fronts are 35% worn hope they do to 38k.
    It depends on how badly worn they are not every time you need to change discs more like second time.
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. brake pads
    By HEP in forum Handling & Braking
    Last Post: 17th October 2008, 23:32
  3. brake pads
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 09:38
  4. brake pads
    By dwdwdw in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2008, 10:25
  5. Brake Pads
    By phildews in forum Handling & Braking
    Last Post: 15th July 2007, 20:06
