Results 1 to 3 of 3
Thread: Steering rack replacement - is it DIY?
    Jul 2011
    Devizes
    Default Steering rack replacement - is it DIY?
    Hi there, I'm in need of a new steering rack as mine is leaking and my steering a s bit limp and seems to steer itself depending on the dips in the road. The question is, do you need to do it on a ramp and drop the subframe or will it come out through the wheel arch? I'm not too bad at working on the car, but not done a steering rack before. I know I'll need to do the tracking etc afterwards, but if I do this myself, it'll save about 4 or 5 hours labour at a garage. Vauxhall just quoted me £1200to do it!! Car is Vectra C 1.9CDTI 150 2005. Many thanks, Mark
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    did mine a few weeks ago ( 2003 2.0 DTi ) to get it out through the wheel arch you need to lower the back end of the subframe , getting the bolt out & back in again that holds the pipes into the rack was fun as well .
    also depends on where the pump is mounted , mine is behind the o/s foglight although I think yours might be on top of the rack .
    Aug 2009
    Eastleigh
    I had a veccy B some years ago with a leaking rack, it was dripping about every second. Vauxhall quoted me £800+, but went to see my local mechanic and he emptied most of the fluid reservoir and filled it up with Wynn's Automatic Transmission and Power Steering Stop Leak and Conditioner. I had to top it up a bit after about 20 mins of driving, but it stopped the leak! Never has to top it up again in 2 years.
    A tin of the stuff was about a tenner, so well worth a go...
  1. Need a new steering rack :(
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2010, 17:44
  2. steering rack??????????
    By slick91 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 17:14
  3. Steering Rack
    By rob1964bike in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2010, 14:27
  4. Steering rack
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 01:50
  5. steering rack
    By kevin hunter in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2008, 20:25
vectra c steering rack removal
vauxhall vectra c steering rack removal
vectra c steering rack replacement
vectra steering rack replacement
vauxhall zafira steering rack removal
vauxhall vectra steering rackhow to change steering rack vectraexchange steering rack vauxhall vectra 1.9 ctdihow to replace steering rack on vectra 2007 cdticorsa c steering rack removalvauxhall vector steering rackvauxhall vectra steering rack repairvauxhall insignia 2009 steering rack removalzafira a steering rack removalhow to replace.steering rack on insigniahow to change a steering rack on a vauxhall vectravectra c steering rack change www.vectra-c.comvauxhall vectra cdti steering rack removalvectra c steering rack change2005 vauxhall vectra c 1.8 steering rack removalwhat tools do i need to change vauxhall vectra c steering rackremoving vectra c rackvectra 05 steering rack removalhow to take the steering rack off a 04 vectra
