Results 1 to 10 of 23
Thread: 1.8 to 3.2 v6
    Dec 2011
    teesside
    Default 1.8 to 3.2 v6
    Hi everyone, thibking of getting rid of my 1.8ls and getting a 3.2 v6. just wanting to know if there is anything I should look out for?
    thanks
    Dec 2011
    Seaham
    A large hole in your wallet from the increased fuel consumption??
    Dec 2011
    teesside
    Quote Originally Posted by Ben50n View Post
    LOL dont really use my car alot as I have a works van
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    just a toy your after
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    Quote Originally Posted by brtsam1 View Post
    thanks
    a countrywide petrol station map & maybe an ex water board water bowser that you can fill with petrol & tow around
    joking aside , you need to know the belt history & watch for oil leaks from the rocker covers , not much idea other than that .
    Dec 2011
    teesside
    Quote Originally Posted by DTi Elite View Post
    i will just install another tank in the boot and my trailer should be ok with 3 tanks. lol, thanks for the advise thought the belt, they should have put a chain on it. other tha that just usual checks, oil and water leaks etc
    May 2012
    chelmsford
    There are quite tough I give mine a hard time and it takes it all in its stride. Get a panel filter and a decent breathing exhaust and that really helps these out alot. Fuel yes they do use it without a doubt but the six cylinder is a heavenly noise and addictive. Get the pre cat removed and it burbles and pops well.
    Cheshire
    you will often see 'mayo' in the neck of the oil filler cap, this is normal!! to cure......... you just remove the offending extension. Obviously check the coolant for signs of head gasket failure which happens occasionally. My GSI had three broken springs which I failed to spot! my gearbox has a whine in 5th. If the car has snowflakes you would be wise to check the back of the rim for cracks or repairs, however this is not easy!
    Belts are very robust and never fail on their own something else fails first, ie water pump, oil seal, tensioner or guard, or a poor DIY job. better than the chain on the 2.2 imo. not sure about the pre cats, but i know the main cat removal, cat back and intake mods give a solid 20bhp gain.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    And a huge smile on your face
    May 2012
    chelmsford
    Oops my bad meant main cat not the pre cat . It does give a good difference in power
