Thread: Fans On All The Time!!!!
    Sheffield
    Unhappy Fans On All The Time!!!!
    Hi Folks!
    The other day i posted a thread for help with a problem i was experiencing with my 52 plate GSI. The temp guage was'nt moving for ages (1/2 hour) and then it starts to move but goes up and down. Although the heaters seemed to be getting warm?? Now then, the latest problem is i got into the car today and noticed when i started the engine both fans came on. I took the car out for a 10 mile run and on my return both fans were still on. I then left the car for 7 hours started it up and both fans came on again from cold!!! I then set off again and took the car on another run including down the motorway, did about 15 miles and the fans never went off. the heaters are now not getting very warm at all!! I notice that when i turn it off the main fan stops but the second fan keeps running for a couple of mins then turns itself off, as if the car has been running for ages in hot weather!
    Any ideas, or have i bought a bag of knackers!!!!
    PS do you think if i disconnected the battery it may correct itself or maybe it could be down to a faulty thermostat.
    Greg.
    Thermostat is a possible but either way i would get it checked out pretty sharpish !!!!!!!!
    either that or a failed fan temp sensor switch.. screws in the side of the radiator..
    EDIT:.. just a thought, i wonder if the two are both factors of the cooling control module failing???..
    Mileage : 000
    Do the 3.2s self vent, as it might be an air lock in the radiator..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    ive seen a vec c do this before ....we couldnt find a fault with it ...all we did was disconect the battery for a few min and it hasnt had a problem sinse ..think the uec has a mind of its own .......try it you aint gonna loose nowt ....but remember you will need a car pass for the radio code ...
    Sheffield
    Benny!!
    Cheers mate. Did a battery reset and everything is ok now, even cleared my spanner light off the dash! Now all i have got to do is get the temp guage thing sorted. Thinking this is a dodgy thermostat more and more now though as warmed the car up today in the garage and guage went up as normal, then took it out for a run and when the car was on the move the guage dropped off. Also turned air con off and noticed heaters were not very warm.
    Greg.
    well, thats a result then.....
    be warned thou that changing the thermostat is still an involved job on the V6..quite a bit of deep digging will be needed..
  1. Long Time Looker, First Time Poster......
    By Whisky in forum Introduce yourself.
    Last Post: 26th March 2011, 22:37
  2. F1 fans
    By ade0303 in forum General Chat
    Last Post: 25th October 2008, 10:07
  3. Sorry WBA Fans
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 5th April 2008, 14:39
  4. FAO All the Man Utd fans.....
    By thegoldenbullet in forum The 'Off Topic' room
    Last Post: 10th March 2008, 12:35
  5. For all you BB fans
    By Ride-On! in forum General Chat
    Last Post: 6th August 2006, 09:44
