Thread: Mileage display
    Jul 2012
    Doncaster
    Default Mileage display
    Hi I'm looking for some advice I have a set of clocks for a vec c that I want to do a colour change on but the mileage display as a small part that dosent display! I have stripped it down and the ribbon that connects it to the pcb as a small hole, so I am wondering if I can just replace the ribbon and screen or will it need to be a full new speedo?
    Cheers Dan
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As far as I am aware it's a full replacement
    If its only part of the ribbon that's damaged you may get a away with carefully soldering a repair wire over the damaged area
    Jul 2012
    Doncaster
    Ye it's just one strand mate but it feels plasticy lol.
    What about scratching the strand and sticking a wire to it or maybe one of those pens that repairs rear window heater lines??
    cheers for reply Dan
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It maybe worth ago.
    I meant if you scratch plastic back to reveal the copper stands you could repair it.
    Not sure if it would work but gotta be worth a try anyway
    Jul 2012
    Doncaster
    Just been reading the net and apparently it's conductive plastic lol so I will have to sticking a repair to it or trying to peel a ribbon from scrappy and glue around the conductive bits!
    I will try a repair tonight just hoping someone else on here as repaired one before and give me a good clue lol.
    Cheers Dan
    Jul 2012
    Doncaster
    Does anyone think as daft as It may sound, could I bridge the very small hole by stapling the ribbon then taping behind and using conductive paint then taping this side?
    Cheers Dan
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. ECU Mileage vs Speedo Mileage
    By Jonsey in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 15:28
  3. Mileage beyond zero
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2011, 20:30
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. What mileage?
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2007, 12:02
