Results 1 to 3 of 3
Thread: Dmf change
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default Dmf change
    Evening all. I'm toying with the idea of changing the flywheel myself has annyone managed to do it? If so what do I need to look out for and do while I'm there. Goes without saying will change the clutch. I spend my days fixing fighter aircraft so I think I have the ability. Any special tools required apart from a flywheel lock?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You need get it up as high as you can to give you room to get subframe off.
    Advise I'd say is use bungees on steering rack as it saves messing around with steering joint.
    A flywheel locking tool will be helpfull when torturing bolts up but a big flat blade screwdriver does same trick
    Id also recommend draining gearbox oil (ensuring to can undo fill plug first) as saves worrying about making a mess.
    Chane slave cylinder at sane time.
    An extra pair of hands to help. Ench press box in an out will be useful to
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Recommend using a impact wrench when i did mine struggled for ages trying to loosen flywheel bolts impact wrench loosened them in a matter of seconds Then when putting things back together refit starter motor before refitting drive shafts that extra room saves a lot of swearing lol
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
