Thread: How to Bleed Radiator
    Jul 2012
    Belfast
    Default How to Bleed Radiator
    Hope this hasnt been covered before but how do you bleed the radiator on a 1.9 cdti (150)?
    Is it just removing expansion cap
    wait for it to reach normal temp
    then add coolant as required?
    thanks in advance
    Barrow In Furness, Cumbria
    Remove the coolant cap.
    Turn heaters to hot on fan speed 2
    Rev car to around 2k and wait to reach normal temp.
    Should have blown any trapped air out by then.
    Wait to cool and check coolant level.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You could always use the black bleed screw on the silver pipe between the engine and the radiator pack
    May 2012
    chelmsford
    What Chris sri said
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I thought the System on the Vec was self bleeding, the header tank being at the highest point thus any air in the system naturally ends up in the header tank.
    11 Post(s)
    Where does it go from the header tank though? Unless the tops off then it can't go anywhere.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    In to the air space in the header tank, above the coolant. Any trapped air that's expelled from the coolant would then require further topping up of the coolant, usually the following day when the coolant has cooled.
    11 Post(s)
    Quote Originally Posted by Chris SRi View Post
    As DasArab says - into the airspace.
    Air is fairly easy to compress, hence why there is an air gap in the header tank.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by paulhb View Post
    This is the correct way as per TIS.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Clutch Bleed
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 19:36
  3. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
  4. Any one recommend a bleed kit?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 00:33
  5. How DO you bleed a diesel
    By craigbarlow18 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2008, 08:04
cdti rad bleeding
bleed opel vectra c radiator
vectra c bleed points
