Thread: Retro fit heated front seats
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Retro fit heated front seats
    I know there are umpteen threads on this but none seem to have many answers
    I have the sri leather that I kept from my old car and before the winter comes i'd like to get the heated seats going on my facelift sri.
    I have the wiring behind the plugs (on the dash) and all of the fuses etc are in place on the REC but there is nothing in the floor loom plugs. Do I just need the wiring from the foot well multi plugs to underneath the seats? Could I also add in the rear electric window looms while I have the carpets/seats out?
    Also will the front seats need tech2'd when I get the wiring in or will everything work as soon as the circuit is complete?
    Strange thing is that I have the wiring for the rear heated seats
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    a member did my body loom and worked strait away. it was easy if your good at wiring no tech2 required. you can do rear electrics while your their but that does need tech2.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers dan thats good to know, I know the windows will have to be tech2'd but i'm not in a hurry to fit them just yet. The arse warmers are a must though
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    you should only have the plugs for rear heated seats... also when doing the front seats you don't take the carpet up.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Hallelujah! That makes the job just slightly easier, does the wiring run along that join in the carpet and along to the door sill?
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    yes and through under the arm rest. but you tuck that in the carpet joint.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ok so both the driver and passenger seat's wiring comes from the passenger side?
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    front driver side through the arm rest and to front and rear passenger side.
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    john . Paul hb /and dean did this to caveman niges wifes car , out in all the wiring for seats elec and other bits , maybe a pm to either one off them , dean also did most off the work changing all the wiring and heat pads over from my elite to the vxr interior ,with the help off a couple off other members .
    the vectra has gone , but not far away so ill still see it form time to time
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers Khalid
  1. Info needed , heated seats , retro fit !
    By biffbangpow in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 22:38
  2. Retro fitting heated seats (front)
    By Keithy in forum Styling
    Last Post: 8th November 2012, 23:11
  3. heated front seats
    By Vectra edd in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2012, 17:58
  4. heated seats, possible retro fit??
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2010, 16:43
