Thread: Rear Lower control arm
    UK
    Default Rear Lower control arm
    Hi
    The inner bush of my rear control arm is squeeking really badly. Its the arm that holds the rear spring (item 17 - http://opeloem.com/vauxhall/vectra_c...nsion_arm.html)
    Just wondering if anyone has bought a new arm and if so how much are they.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Think is bush on ur upper control arm mate position 13 plenty threads about it here
    UK
    Quote Originally Posted by Sebastian View Post
    Its not item 13, I'm well aware of that arm, I've just redone that one anyway. The sqeak was there before and after changing item 13.
    I've sprayed WD40 on the inner bush of item 17 and it becomes silent again, doesn't last long though, noise appears again within 24 hours.
    South east
    You could try doing a search on ebay to see if anyone sells just the bush, like for example the upper arm's outer bush can be bought on ebay even though Vauxhall don't sell just the bush. However, many sellers give little or no information on which components their bushes are for, so it can be a bit of a lottery trying to buy the right one.
    UK
    Couldn't find any info on just the bush, I did find the Powerflex bushes though http://www.ebay.co.uk/itm/POWERFLEX-...ht_5437wt_1185. I think these are the right ones, proberly be cheeper than a new arm from the dealers.
    And here are the instructions for fitting them http://www.powerflex.co.uk/i/product.../80-1216fi.pdf. Sounds simple enough, but I bet the bolt that goes through it wont move!!!!
  1. rear lower control arm bush
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 13:32
  2. Rear lower control arm
    By DHobbs in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2012, 07:27
  3. Lower control arm signum
    By arkhan78 in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 10:59
  4. lower control arm with ball joint, help
    By wrayballs10 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2009, 20:13
vectra c lower control arm
vectra c rear lower arm
vectra c rear lower control arm bush
vauxhall vectra lower arm
lower control arm vectra c
vectra c rear trailing arm
how you know lower control arm bush vectra c is gone
vectra c rear suspension arms
how to vectra c lower control arms
vectra c lower control arm part number
lower susoension arm vectra c
vectra c rear lower control arm bush hiwto
vectra c rear bottom suspension arm
vectra c lower control arm bush
vectra c rear control arm
vauxhall omega estate rear control arms
