Thread: The Vectra Lives Again!!!
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Talking The Vectra Lives Again!!!
    Well i've got the car back!
    Had a 2nd hand gear box, clutch, and flywheel fitted from a 2003 dti with 68000 on the clock (clutch looked nearly new).
    Car runs and sounds better than it ever has done.
    Turns out my gearbox had sprung a leak (although i never saw any oil patches) and had NO oil in it. This in turn made the gearbox start to seize, thus destorying my clutch and flywheel.
    The clutch was as smooth as sheet metal and wafer thin, and the flywheel had about 1.5 inches of movement in it. Mechanic wondered how the hell the car was still working!
    Anyhow, I've seen the parts and seen how bad they were to make sure I wasnt being ripped off.
    £440 all in including gearbox oil and new driveshaft seals.
    Happy me!
    Russ
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Good stuff, glad your going good again.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 130000
    Quote Originally Posted by thegoldenbullet View Post
    Happy me!
    Russ
    you done well there
    bargin
    a very good find
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Glad you got it all sorted
    Mar 2007
    Grimsby, Lincs.
    Best tHing is mate, they sourced a second hand one and drove a 30 mile round trip to pick it up. Quality service and quality work.
    Devon
    Happy me!
    Russ
    Glad you’ve got it sorted!
    Did you go back to the person who replaced your passengers side inner driveshaft boot?
    The easiest way (and way most professionals will do it) is to remove the inner joint from the gearbox. Your gearbox oil will drain out if this is not plugged sufficiently. It is way too much of a coincidence that you have had the passenger boot replaced, and then you have all these problems only to be told your gearbox oil has run dry.
    It is very unlikely your gearbox developed a leak that would mean it would drop all of its oil, unless someone drilled a whole in the pan!
  1. who lives near York
    By lordreeson in forum Engine & Drivetrain
    Last Post: 28th February 2011, 22:03
  2. superman lives on.....
    By david.aka.judas in forum Comedy & Humour
    Last Post: 17th October 2010, 17:13
  3. Who lives in leeds .....
    By bobby-tupper in forum General Chat
    Last Post: 24th February 2009, 22:38
  4. Mexican! Run for yer lives!
    By BlueRob in forum General Chat
    Last Post: 7th February 2009, 17:32
  5. anyone that lives in wakefield
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2008, 12:24
