Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: DAytime running light activation
  1. #11
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    You cant have "sidelights" if its the small w5w bulb on on its own. for me side light is like the normal light as when you drive at night.
    Front DRL is in the UEC
    Rear DRL is in the REC.
    So you have to change it both places if you want both places.
  2. #12
    Jul 2009
    Yorkshire
    Quote Originally Posted by MrDerv View Post
    Facelifts had the option in the UEC for front foglights as DRL's. Tried options 3 & 4 on a friend's facelift and it uses the fogs....
    Do you recall if the front fogs dim when used as DRL's then return to full brightness if used as fogs?
  3. #13
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by kenp View Post
    Thanks Ken. Does anyone have any thoughts as to whether the configuration of having dipped beam (which I assume is Ken's explanation) on as DRL's, would be considered a "legal" use of headlights in the UK ?
  4. #14
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Facelifts had the option in the UEC for front foglights as DRL's, but pre-face only activates sidelights or dipped beam.
    Tried all 4 DRL options on mine using the program that must not be mentioned, and preface only works with DRL option 1 & 2. Tried options 3 & 4 on a friend's facelift and it uses the fogs.
    On my pre facelift I can do all the DRL options with vauxcom.
  5. #15
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    It would not be illigal ;-) but DRL are not mandatory in the UK, but not prohibbeted to have it.
  6. #16
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Signum7060 View Post
    Yes they do. As DRL they are slightly dimmer, and turn off when you turn sidelights on and the fogs return as normal brightness fogs operated via the stock fog switch.
  7. #17
    Jul 2009
    Yorkshire
    Thanks for the speedy reply mate. I wonder if my '57 CDTi will be compatible??
  8. #18
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Thanks again Ken, now I gotta start looking even harder for a "friend" in the Cheshire/Merseyside area with a tech2 and the "knowledge" to do a bit of experimenting with my 04 Gsi
  9. #19
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I wish someone would PM me with details of the not to be mentioned ...........
  10. #20
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I was always of the opinion that this could only be done on the pre facelifts but I'm happy to be proved wrong.
  1. auto headlight switch AND daytime running light
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 08:18
  2. Retro fit Daytime Running Light Wiring
    By yorkshire jim in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 23:23
  3. difference between daytime running lights and daytime styling lights ????/
    By montyfert in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2012, 13:09
  4. Daytime running led strips
    By bigal77 in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 13:11
  5. Daytime Running Lights
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 10:57
https:www.vectra-c.comforumshowthread.php169188-DAytime-running-light-activation
daytime running light rec vectra c
